Where Does the Electric Potential Equal Zero Along the X-axis?
The discussion focuses on finding the point along the x-axis where the electric potential equals zero due to two charges: +2q at the origin and -3q at x=5m. The electric potential is calculated using the equation V=kq/r, and the total potential is set to zero by combining the contributions from both charges. The user derived the equation 2kq(5-x) = 3kqx, which simplifies to 10-2x=5, leading to the solution x=2.0m. Other participants confirm that the calculations are correct without errors. The final answer indicates the location along the x-axis where the electric potential is zero.
cuppy
Two charges lie on the x-axis +2q at the origin and -3q at x=5m. The point on the x-axis where the electric potential has a zero value is??
relevant equations-
V=kq/r
my solution-
since electric potential is a scalar quantity i reasoned that when you add the potentials of both charges and equate that to zero i should be able to find where electric potential is zero. i drew out a diagram and my working out is -
V= k(2q)/x + k(-3q)/5-x = 0
rearranging 2kq(5-x)=3kqx
the k and q cancel giving 10-2x=5 ===> solving gives x=2.0m.
have i made any errors in my working or is it all good? thanks in advance :-p
Yep - looks good.
