How Do You Calculate Electric Potential with Opposite Charges?
To calculate the electric potential at a positive charge Q due to both a positive and a negative charge, the potentials from each charge should be summed, not subtracted. Electric potential is a scalar quantity, meaning it does not have direction, so the contributions from each charge can be added directly. The formula for the net potential at point Q is Vnet = V(+) + V(-), where V(+) is the potential from the positive charge and V(-) is from the negative charge. It is important to consider the signs of the charges when calculating their individual potentials. Therefore, the correct approach is to add the potentials together to find the total electric potential at charge Q.
ngkamsengpeter
A positive charge Q between two charge , a positive charge and a negative charge .Now I want to find the electric potential at the positive charge Q due to both the charges . The problem I am facing is do I need to minus the
electric potential due to charge positive with the electric potential due to charge negative . I have this problem because the electric potential is a scalar quantity , so if I minus it , it will look like it is a vector quantity .So do I need to minus it or add it together ?
Because Potential is a scalar quantitu , Vnet=V(+) + V(-) , that is summation of potential at that point due to positive charge + potential at that point due to negative charge , while writing the potential terms take the charge +Q or -Q as the case maybe...
