Electric Load Power: How Does It Maintain?
An electrical load, such as a motor, maintains its power by adjusting the current in response to voltage changes, as described by the formula P = V x I. When voltage drops, the motor increases its current draw to compensate for the reduced power output. This adjustment occurs because the motor requires a specific current to generate the necessary magnetic field for operation. Unlike motors, DC-DC converters can maintain constant power by varying input current inversely with input voltage. Understanding this relationship is crucial for comprehending how electrical loads respond to changes in voltage.
mark g
Hi all.
This question has been bugging me for a while now so hopefully you can help.
I want to know how an electrical load (such as a motor) maintains its power, like when the voltage drops the current increases.
I know all the formulas ( in this case P = V x I ) but want to know how it works.
At nominal operation the motor is spinning fine and sees a current passing through its terminals. Then there is a voltage drop or dip and so it draws more current.
How does it (know how to) draw more current? A motor requires a current to induce a magnetic field and it (if it had a brain) does not know anything about the source. All it wants is a particular current to produce the magnetic field. Where does the voltage relationship come into this.
I have searched and searched but all I can find is it maintains P = V x I, but not how it does this.
Thanks,
Mark.
mark g said:
Hi all.
Thanks,
Mark.
Welcome to the PF.
When the input voltage drops to a motor, the output power of the motor drops.
The only common constant-power loads are DC-DC converters. They use switched currents through magnetics to transform an input voltage into an output voltage at the load current. The input current depends inversely on the input voltage, since DC-DC converters are basically "constant power converters".
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
