Electrical networks(linear algebra)
To determine the currents in electrical networks when they are not labeled, one can assign currents arbitrarily in any direction. The direction of the currents can be adjusted later if calculations yield negative values, indicating the opposite direction. Understanding the principles of voltage drop across resistors and conservation of charge is essential for solving these problems. The discussion emphasizes the connection between electrical networks and physics concepts. The topic ultimately highlights the need for a visual representation to effectively analyze the circuit.
EV33
Determine the currents in the various branches.
Then there is a picture of the network which has batteries, resistors, and nodes.
Most of the problems have the currents labeled.
My question is when the currents are not labled how do you determine where to put them and what direction to give them?
No equations.
By looking at the the various electrical networks in the book it looks like you can put the currents anywhere and in any diretion.
Without the picture, this question makes no sense at all! In any case, it looks like a physics problem to me. The whole point is to find the currents using such physics laws as the drop in voltage over a resistor and "conservation of charge".
I'm going to move this to physics homework.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
