How Do You Calculate Electric Potential Energy in a Multi-Charge System?
To calculate electric potential energy in a multi-charge system, the total potential energy (TPE) is derived from the contributions of each pair of charges. The formula used is TPE = PE11 + PE12 + (PE13 + PE23), where each PE term represents the potential energy between specific charge pairs. The charges are assumed to be brought in from infinity, with specific values assigned to each charge. The user seeks confirmation on whether their approach and calculations are correct. Clarification on the visibility of the referenced image is also requested.
synergix
Compute the electric potential energy for the charge configuration shown below.
http://webct6.nic.bc.ca/webct/RelativeResourceManager/Template/CourseMaterials/CourseContent_2007FA/Assignments/PHY060W_Assignment_07_files/image025.jpg"
PE=-W=qV=q(vb-va)
It is assumed that the charges are being brought in from infinity the -3.0 micro coulomb charge is charge one, 5.0 micro coulomb charge is number 3
TPE=PE11+PE12+(PE13+PE23)
TPE= 0J+[(q1KQ2)/r2] + [(q1KQ3)/r1 + (q2KQ3)/r3]
where q1 is charge 1, q2 and Q2 are charge 2, Q3 is charge 3, r1 is the distance between q1 and Q3, r2 is the distance between charge 1 and 2, r3 is the distance between q2 and Q3.
am I on the right track can I simply solve this equation to get the right answer?
Sorry your image isn't viewable.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
