Electrical resistance of a paraboloid.
The discussion focuses on calculating the electrical resistance of a paraboloid defined from y = 0 to L. The resistance formula used is R = ρ(L/A), with A representing the area of the circular cross-section. The user attempts to express the paraboloid in terms of y = √x and calculates the area as A = πy² = πx. The integration leads to an expression for resistance that indicates infinite resistance as x approaches zero, raising questions about the validity of the mathematical approach. The user seeks confirmation of their calculations or alternative methods for determining the resistance.
BlackWyvern
What would the electrical resistance of a paraboloid from y = 0 to L be?
R = \rho \frac{L}{A}
Okay, so I'll put the parabola (that would rotate into the paraboloid) into the form y = \sqrt{x}
The function A(x) is just the area of the circle, at distance x.
A = \pi y^{2} = \pi x
I'll break the paraboloid up first into a finite sum of discs, from 0 to L.
R = \Sigma \rho \frac{\Delta x}{A(x)}
R = \int^{L}_{0} \rho \frac{dx}{\pi x}
R = \frac{\rho}{\pi} \int^{L}_{0}\frac{1}{x} dx
This integral resolves to:
R = [\frac{\rho}{\pi}ln(x)]^{L}_{0}
Natural log of 0 is undefined, so this would resolve to a numerical answer, as at the limit of x ==> 0, the area approaches zero and this means infinite resistance. But is the maths correct? Or can someone suggest a better way to actually find an answer.
bump. <_<
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
