Calculating the Voltage for a Proton Floating Between Two Boards
To calculate the voltage for a proton floating between two boards, the force acting on the proton must be its weight, calculated as F = m*g. The correct approach involves using this weight to find the electric field (E) by dividing the force by the charge of the proton. The voltage (U) is then derived from the electric field multiplied by the distance between the boards. The initial attempts incorrectly used gravitational acceleration directly as a force, leading to inaccurate voltage calculations. The final calculation yields a voltage of approximately 2.088 x 10^-7 V, which is deemed correct.
Mushroom79
A proton just floating in a field in a between two boards (g=9,82 m/s^2)
What is the voltage U?
distance d = 2 m
charge for protone Q = 1,602*10^-19
E = F/Q
E = U/d
I've tried two different ways of which I don't know is correct
In both cases I assume that F = 9,82 as something must be lifting it upp to make up for the gravitation
Attempt 1.
F = g = 9,82
E = F/Q = 9,82/(1,602*10^-19) = 6,13
E = U/d --> U = E*d = 6,13*2 = 2,26 V
Attempt 2.
E = U/d --> U = E*d = 19,64 V
Careful, you're using g (acceleration due to gravity) as a force. The force due to gravity on the proton would be its weight, m*g.
Oh, I forgot about that
Probably not the right solution considering the answer:
F = m*g = 1,672*10^-27 * 9,82 = 1,642 * 10^-26
E = F/Q = (1,672*10^-26)/(1,602*10^-19) = 1,044*10^-7
E = U/d --> U = E*d = (1,044*10^-7)*2 = 2,088*10^-7
Looks okay to me.
gneill said:
Looks okay to me.
Okay, thank you for the help :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
