How Can Copper Alloys Be Purified Electrochemically?
  • Thread starter Thread starter amarnath
    Electrochemical
Electrochemical purification of copper alloys can be achieved through various methods, primarily focusing on creating a redox couple that allows for the oxidation of impurities while preserving the copper. One common technique mentioned is pickling, which involves treating the alloy with a non-oxidizing acid to solubilize the other metals in the alloy, leaving the copper intact. For organic impurities, heating the copper alloy above 500°C followed by acidic treatment is recommended. The discussion emphasizes the importance of selecting appropriate commercial setups and resources for effective electrochemical purification processes.
amarnath
Hi all
How to purify copper alloys electrochemically ? please describe all possible commerically feseable ways and also pls specify any commerical set ups /resource that can do the above process
Chemistry news on Phys.org
Hello,
I have no knowledge about commercial aspects of electrochemical purification, but I'd say that if you can produce a redox couple on copper, then you can oxidize the other metal and purify it; but the term "pickling" is frequently used for the thing you're asking for, I think.
Pickling is basicly an acidic treatment, but the acid must be of a non-oxidizing one in order not to corrode copper; the other metal(s) in the alloy will eventually be solubilized and leave copper by going into the solution, and copper will remain intact. This may be a good measure.
If the impurities are organic-based, acidic treatment after heating the copper part beyond 500°C will be more helpful.
These are pure-chemical ways to treat an impure copper alloy, but wait for other friends' posts.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
