Electromagnetism - The distance from point a to point b
The discussion revolves around calculating the distance between two points in an electromagnetic context, specifically involving a proton and its interactions. Participants clarify the necessary equations and constants, such as the charge of the proton and the force at point one, to derive the distance. There is confusion regarding the calculation of Q and the conversion of units, which is resolved through collaborative problem-solving. Ultimately, the calculated distance between the two points is confirmed to be approximately 0.00237 meters. The thread emphasizes the importance of accurate calculations in electromagnetism.
Jon Blind
So I want to know the distance to 2. The proton is at v=0 at the 1.
We know that:
q=1.602*10^-19 point 1
L=1mm
v=1.1*10^6 at point 2
F=1.44*10^-12 at point 1
[/B]
E=(1/4πε)*(q/r2)
ΔV=∫E*dr=(1/4πε)*q∫(1/r2)=(1/4πε)*q*(1/r2-1/r1)
ΔU=ΔK=mv2/2
ΔK=mv2/2=ΔV*q=q*(1/4πε)*q*(1/r2-1/r1)
3) The attempt at a solutionI can't seem to calculate the distance. I don't know where I've gone wrong.
L=1 mm. Can you see that this is also ## r_1 ## ?
Exactly and I'm trying to find out r2.
According to my calculations r2=2.28*10^-13 but that seems way too little?
What did you use for the mass of the proton? Also, did you convert ## L ## to meters? Also you need to solve for Q. You can do that because itt tells you the force ## F ## at point 1.
Yes, the mass of the proton is 1.673*10^-27
Epsilon=8.854*10^-12
and q=1.602*10^-19
and q=1.602*10^-19
I see one mistake. You assumed the two q's were equal. See also my edited previous post. You need to solve for ## Q ##.
So Q=F/E ??
I'll give it a try and calculate it now, thankyou very much.
Jon Blind said:
So Q=F/E ??
## F=\frac{Qq}{4 \pi \epsilon_o r^2} ##. They give you ## F ##, ## q##, and ## r ##. You need to compute ## Q ##.
5.87*10^-4m
THANKYOU! Freaking hell I was so confused
Jon Blind said:
5.87*10^-4m
Compute ## Q ## in Coulombs. You need this number for the remainder of the calculations. The answer you gave is incorrect.
How is that possible?
ΔK=mv2/2=ΔV*q=q*(1/4πε)*Q*(1/r2-1/r1)
Q=1.00*10^-9ΔK=mv2/2=ΔV*q=q*(1/4πε)*q*(1/r2-1/r1)
(mv^2*epsilon*m*4*pi)/(2*q*Q)=1/r2-1/r1
(1.673*10^-27)*)((1.1*10^6)^2)*4*pi*(8.854*10^-12)/(2*(1.602*10^-19)*(1.00*10^-9))=1/r2-1000
1/r2=1702.97
r2=5.872*10^-4
1/r2=1702.97
r2=5.872*10^-4
Close, but your final term should read ## \frac{1}{r_1}-\frac{1}{r_2} =1000-\frac{1}{r_2} ## . ( ## r_2>r_1 ##). ## \\ ## Once you correctly solve for ## r_2 ##, you then need to compute the distance ## D=r_2-r_1 ##.
In that case r2 should be= 0.00337m
r2-r1=0.00237
Likes Charles Link
That's what I got also. :) :)
Now solve for ## D ##. See my edited post #12.
Yep I saw it, and I edited my post and did it ;)
r2-r1=0.00237
Likes Charles Link
