Electron accelerated between plates
  • Thread starter Thread starter pengumon
    Electron Plates
An electron is accelerated horizontally from rest in a television picture tube by a potential difference of 6380 V, achieving a horizontal speed of 4.73E7 m/s. After passing through two horizontal plates with a potential difference of 118 V, the vertical acceleration calculated is 3.79E14 m/s², resulting in a final vertical speed of 2.04E5 m/s. The angle θ is determined using the final horizontal and vertical velocities, leading to the correct calculation of θ = 0.124 radians. The initial approach using distances was incorrect; the final velocities must be used to find the angle.
  • Understanding of kinematics equations
  • Familiarity with electric potential and force equations (E=F/q, V=PE/q)
  • Knowledge of conservation of energy principles
  • Basic trigonometry for angle calculations
  • Study the effects of electric fields on charged particles in physics
  • Learn about the relationship between potential difference and kinetic energy
  • Explore advanced kinematics problems involving multiple dimensions
  • Investigate the behavior of electrons in different potential configurations
Physics students, educators, and anyone interested in the dynamics of charged particles in electric fields will benefit from this discussion.
pengumon
An electron is accelerated horizontally from rest in a television picture tube by a potential difference of 6380 V. It then passes between two horizontal plates 2.55 cm long and 5.47 cm apart that have a potential difference of 118 V. At what angle θ will the electron be traveling after it passes between the plates?
Kinematics equations, E=F/q, V=PE/q, V= -Ed
I first used conservation of energy to solve for the horizontal speed, Vq = (1/2)mv^2, to get 4.73E7 m/s. I then used that to find the time in between the plates, v = x/t getting t = 5.39E-10 s. Then I found the force due to the plates, F=Eq=-Vq/d= 3.45E-16 N = ma. Using this with the mass of the electron I solved for a, the vertical acceleration, to get a = 3.79E14 m/s^2 = (final vertical speed - initial vertical speed)/t. Since initial vertical speed = 0, a = v/t and I got the final vertical speed as 2.04E5 m/s. I then used (final speed)^2 = (initial speed)^2 +2ay to solve for y as the vertical distance travelled, which I got as 5.50E-5 m. I then set up a triangle so that tanθ = y/x = (5.50E-5)/(0.0255), and I finished with θ=0.124. This is the wrong answer, though and I'm not sure where I'm going wrong. Any elucidation is much appreciated!
Just kidding, I figured it out. I need to use the final horizontal and vertical velocities, not distances, to find the angle.
  • · Replies 38 ·
  • · Replies 28 ·
