Electron Distribution in a Simple Circuit
In a simple circuit with a lamp and power source, current flows from negative to positive, but there is no higher concentration of electrons before the lamp compared to after it, as current is contiguous throughout the circuit. This principle is explained by Kirchhoff's Current Law (KCL), which emphasizes the continuity of current. The voltage across the bulb is not due to a difference in electron concentration but rather the energy difference provided by the power source. Textbooks and educational resources discuss charge distribution in circuits, although peer-reviewed articles on such basic concepts are rare. Understanding these fundamentals is crucial for grasping electric circuit behavior.
JakeyG14
Hi guys,
I'm trying break down a simple circuit composed of a lamp and a power source down to it's basics.
So, I know that the current will flow from negative to positive. However, is it correct to say that there are more electrons before the lamp than there is after the bulb? This difference in concentration of electrons is what causes the voltage across the bulb.
I know that the electrons will be moving at the same rate at all points in the circuit, but is there a higher concentration of electrons before they "meet" the bulb than after the bulb?
I know some of you will laugh at such a simple question, but it's something that's been annoying me.
JakeyG14 said:
Hi guys,
Welcome to the PF.
No. the current is contiguous. There is a circuit analysis technique that uses this continuity -- it's called Kirchoff's Current Law (KCL). You can look it up on wikipedia.org to learn more...
<< URL deleted by berkeman >>I hope this qualifies as a valid reference. It has pictures of charge distribution in DC circuits.
PS: berkeman would you please reply to my pm, thanks
Cheers guys.
I'll definitely take a look at the aforementioned links.
No, sorry. That self-published paper has problems, so I deleted the reference to it. If you can find a similar paper published in a mainstream peer-reviewed scientific journal, then we will allow it.
I did reply to your PM just now.
"Electric Circuits & Networks" By Suresh Kumar, Kumar K. S. Suresh
http://books.google.com/books?id=ZzeXM-IQnIUC&&pg=PA9
See page 9:
1.2 "A voltage source with a resistance connected at its terminals",
1.2.1 "Steady-state charge distribution in the system"
Figure 1.2-1 "Steady-state with a resistance connected across DC voltage"
berkeman, this is a textbook, if this does not qualify, I don't know what is.
Sorry I could not find anything available online in peer-reviewed journals because these kind of things are so basic and well studied they no longer appear in peer-reviewed journals. They do appear in textbooks and teaching aids though.
I believe Feynman has addressed this subject in his lectures but I do not have access to them at the moment so I cannot quote the exact page/paragraph. I'll look it up later.
The following papers appear to deal directly with subject, unfortunately I do not have access to them either:
Rosser, W. G. V., 1963, What makes an electric current “flow”, American Journal of Physics, 31,884 - 885.
Rosser, W. G. V., 1970, Magnitudes of surface charge distributions associated with electric current flow, American Journal of Physics, 38, 265 - 266.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
