Electron-Positron Collision finding Kinetic Energy
The discussion centers on calculating the minimum kinetic energy required for an electron-positron collision to produce a pion pair. Each pion has a rest mass of 140 MeV/c^2, while the electron and positron have a rest mass of 0.51 MeV/c^2. The total energy before the collision includes the rest mass energies of the electron and positron, plus their kinetic energies. The total energy after the collision must equal the rest mass energy of the two pions, with the minimum kinetic energy of the pions set to zero for this calculation. The participants emphasize the importance of correctly setting up the energy conservation equation to solve for the kinetic energy K.
phamula
Positive and negative pions, denoted \pi + and\pi - , are antiparticles of each other.
Each has a rest mass of 140 MeV/c^2. Suppose a collision between an electron and positron, each with kinetic energy K, produces a \pi+ , \pi- pair. What is the smallest possible value for K?
E=mc2
E(kinetic)=E(total)-E(at rest)
I need to fine Kinetic Energy, but I do not know how to find E(total). E at rest is 140 MeV
E=mc2
What is the initial rest energy of the electron and the positron? What is the total energy, including kinetic, of the electron and positron? Write that out. That will be the left side of the energy conservation equation.
What is the final rest energy of the two pions? What is the total energy of the pions (including final kinetic energy). What is the minimum value for the kinetic energy of the pions? Use that value for the final kinetic energy. That will be the right side of the equation.
That gives you one unknown (K) which you can now solve.
AM
This is what I came up with, but I don't think I am setting up the variables right.
melectron=0.51 MeV/c2
mpositron=0.51 MeV/c2
mpion=140MeV/c2
E0 electron + E0 positron + Eelectron total + Epositron total = E0 pion 1 + E0 pion 2 + Epion 1 total + Epion 2 total
mc2 + mc2 + (mc2 + (1/2)mv2) +(mc2 + (1/2)mv2) = mc2 + mc2 + (mc2 + (1/2)mv2) +(mc2 + (1/2)mv2)
(.51 MeV) + (.51 MeV) + (1/2)(.51MeV) + (1/2)(.51MeV) = (140 MeV) + (140 MeV) + (1/2)(140MeV)v2 + (1/2)(140MeV)v2
mpion=140MeV/c2
Your equation makes no sense.
m_ec^2 + m_pc^2 + 2K = total energy before
Let KE after = 0 (minimum case):
m_{(\pi^-)}c^2 + m_{(\pi^+)}c^2 + 0 = total energy AFTER
How is the total energy before related to the total energy after?
AM
Thanks! I found out that mastering physics accepted 3 sig figs specifically and that screwed things up for me. :rolleyes:
