Electron velocity through earth's magnetic field
To maintain a straight-line path, the velocity of an electron traveling perpendicular to Earth's magnetic field must match the force of gravity with the magnetic force. The calculation shows that the required velocity is approximately 9.31E-7 m/s, which seems unusually slow. This slow velocity highlights the minimal impact of gravity on the motion of an electron due to its small mass. The discussion confirms that the calculations are correct, and the result aligns with the understanding of electron dynamics in a magnetic field. The findings illustrate the weak influence of gravity on such tiny particles.
sa1988
Electron is traveling in line with the equator, perpendicular to Earth's magnetic field of 6E-5 Tesla. What velocity is required for the electron to stay in a straight line path, such that it's weight is exactly matched by the magnetic force against it.
F = q.(v×B)
I've actually done a whole module on electromagnetism before, right through to Maxwell's equations etc. However I've changed to a new university and am required to go through it all again, because that's just the way their course goes. The work is trivial enough but the answer I've got here is strangely small so I need to double check to see if I've missed something.
Electron weight needs to match the Magnetic force. So...
F = mg = q.(v×B) = qvB (because of perpendicularity so can 'ignore' cross-product formalities)
v = mg/qB = (9.11E-31 * 9.81) / 1.60E-19 * 6E-5)
v = 9.31E-7 m/s
Now this seems incredibly slow to me. I understand electrons are very, very small, but I've never come across anything where such an incredibly slow velocity would be of any use at all.
So, am I correct or have I made some glaring error somewhere?
Thanks.
It means that the gravity acting on the electron is really weak and doesn't affect much to the motion of electron.
Likes sa1988
Great stuff, I take it there's no problem with the answer then :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
