Electronic partition function for molecule with degeneracies
3 replies · 7K views
wiveykid
A atom had a threefold degenerate ground level, a non degenerate electronically excited level at 3500 cm^-1(setting the energy orgin as the ground electronic state energy of the atom ) and a threefold degenerate level at 4700 cm^-1 . Calculate the electronic partition function of this atom at 2000K
qel= sumnation{i=0inf}[gel*exp[-(Ei-Ei-1)/(kbT)]]
I see three levels in the problem
I believe, given the problem statement, that g0=3, g1=1 @3500cm-1, g2=3@4700cm-1
I came up with the equation
qel= 3+ 1*exp[-(E1-E0)/(kbT)] + 3*exp[-(E2-E1)/(kbT)]
T= 2000K, kb= Boltzmann constant ~1.38e-23
I am having trouble finding the energy values for each excited state. I am not sure if E=hv applies to this problem.
Also I am not too confident in the equation I found.
If anyone understands degeneracy, electronic partition functions or excited electronic stateI would greatly appreciate any help
I would assume that you just use
E = h f
= h c / lambda
= hbar c k
, no? (I'm assuming that the inverse lengths that the problem specifies are wavenumbers of photons that would be emitted from the corresponding energy differences.)
yes I guess I can just multiply those numbers by c to get the excited state energies. Doing this it seems that all the exponentials go to zero because kbT is so small and c is so large. I guess the electronic partition function ends up being equal to 3
There is more to the calculation than just kBT and c. Try calculating the value of [itex]\frac{\Delta E}{k_B T}[/itex] for the two excited states.
That's pretty much correct, except that it is E2-E0 in the final term.
Yes, it does.
