Studying Electronic properties of materials in reduced dimensions
The discussion revolves around choosing between a theoretical or experimental approach for an assignment on the electronic properties of materials in reduced dimensions, specifically focusing on quantum dots and nanostructures. The participant is an undergraduate student engaged in a summer introductory research course. Key considerations include the level of complexity in simplifying electronic properties and the distinction between planning an experiment versus actually conducting one. The conversation emphasizes the need to clarify the resources available for performing experiments and the specific dimensions being analyzed, whether they pertain to classical or quantum mechanical frameworks.
suhruth
I Had been given an assignment on electronic properties of materials in reduced dimension as mentioned above so I have been given another option to choose whether it to be a theoretical approach or experimental approach which one should I choose.
Welcome to the PF.
What level in school are you? Is this for a short paper, or a senior project, or a dissertation?
And what do you mean by reduced dimensions? How much are you trying to simplify things? A
nd how can you simplify the electronic properties of materials by just reducing the number of dimensions that you use to analyze them? Are you talking about classical V=IR kinds of things, or quantum mechanical band theory?
By "experimental approach" do you mean (a) planning an experiment, or (b) actually performing an experiment? If (b), do you have (1) the resources to either fabricate or obtain a sample and (2) the equipment to take the measurements?
Welcome to the PF.
I'm an undergraduate student ,planning to work on Quantum dot ,nano structures and plan to go little advanced in this field . This is just a summer introductory research course.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
