Electrons vs Ground: What's the Difference?
  • Thread starter Thread starter High_Voltage
    Electrons Ground
Electrons flow due to potential differences, not because they "want" to go to ground. Both AC and DC currents can flow to ground if there is a conductive path and a sufficient voltage difference. In the case of a Tesla coil, the high voltage creates a path for electrons to discharge to the ground. Connecting the negative side of a battery to ground alone will not drain it; the positive terminal must also be connected to complete the circuit. Understanding these principles clarifies the behavior of electricity in relation to ground.
High_Voltage
I know that electrons want to flow to ground (earth ground) so I have a few questions: Is it only AC current that flows to ground(I ask this because I saw a video of a person with a Tesla coil on their car and the electricity was going to the ground)? If I put the -(negative) side of a 9V battery on a cold water pipe that is connected to ground will the electrons flow, and drain the battery.The video with the Tesla Coil:
Watch from 2:03 to 2:29
It is just not true that electrons "want" to do anything.
Electrons flow where there is a potential difference to drive them. They flow from a negative potential to a positive potential depending on the existence of a conducting path.
This is the case when sky-to-ground lightning strikes occur and the storm clouds develop a negative charge relative to ground because even air provides a conducting path if the voltage is high enough.
If the charge was positive, then electrons would flow FROM the ground to the storm cloud.
Connecting one side of a battery to ground does not drain the electrons unless the other terminal of the battery is also connected to ground.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
