Electrostactics- honors physics problem
The problem involves calculating the electric field at the center of a square formed by four point charges, each with a magnitude of q = 6.4 x 10^-19 C. The charges are positioned such that two are positive and two are negative. The solution requires using the GUESS method and relevant equations for electric field and force. After calculating the contributions from individual charges and combining them, the resultant electric field at the center is found to be E = 3.26 x 10^-6 N/C. The calculations confirm the correctness of this result.
Creative-Amy
Four point charges of equal magnitude q = 6.4 X 10-19 C are placed at the corners of a square with side length a = 10 cm. Calculate the electric field at P, the center of the square, if q1 and q4 are positive and q2 and q3 are negative. (Use GUESS method.) Answer E = 3.26 X 10-6 N/C
E=Fe/q E=kQ/r2 Fe=kq1q2/r2 Q=Ne F=ma
k=9.0E9
e=1.6E-19
Q=Ne
Q=1*1.6E-19
9E9*1.6E-19/(.10^2)
And now I'm confused...I don't know what steps to follow, can anyone help?
Welcome to Physics Forums.
k=9.0E9
e=1.6E-19
Q=Ne
Q=1*1.6E-19
9E9*1.6E-19/(.10^2)
Q is not 1.6e-19, that is for an electron or proton. Q is the value given in the problem statement.
Okay, start by calculating the electric field, at the center of the square, due to just one of the charges.
equations
Fe=kq1q2/r^2
resultant=sqroot(x^2+y^2)
q4-q1
y component
((9E9)(6.4E-19)^2)/.1^2 = 3.6864E-25
q3-q4
x component
Solve for resultant
sqroot( 3.6864E-25^2+3.6864E-25^2) = 5.21E-25 = Fe
equation
E=Fe/q
q=1.6E-19
5.21E-25/1.6E-19 = 3.258E-6
Answer= 3.26E-6
Correct?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
