Electrostatic forces and distance when considering changes in potentia
As distance increases between charged particles, potential energy decreases, leading to an increase in kinetic energy of gas molecules. This aligns with the electric potential energy formula but contrasts with gravitational potential energy, which may require further exploration. The confusion arises from the assumption that gas molecules are oppositely charged; however, gas molecules can still attract each other through electric forces despite having zero net charge. The potential energy of these molecules increases as they move farther apart, reflecting the nature of their interactions. Understanding these concepts is crucial for grasping the behavior of gases under varying distances.
Hereformore
Question:
Relevant formulas:
kei + pei = kef + pef
U = kqq/r
Attempt at solution:
I thought that as distance increases potential energy would go down and so that energy would have to go to the kinetic energy of the gasses, so kinetic energy would increase.
This is consistent with the formula for electric potential energy but not consistent with the potential energy for gravity (wondering if there's a reason why/why it isn't consistent).
The book I am using says that since the molecules are attracted to each other, as they get farther away, their potential energy increases.
Is that because we're assuming the gas molecules are oppositely charged? So potential energy would be negative, and thus less negative when further away?
Hello, Hereformore.
Gas molecules generally have zero net charge. Nevertheless, they can still attract each other via electric forces! You can read about it here or here .
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
