Electrostatic potential energy for concentric spheres
The discussion revolves around calculating the total energy stored in the electric field between two concentric metal spheres with given charges and radii. The problem is situated within the context of electrostatics and energy storage in electric fields.
  • Participants explore the justification for treating the spheres as parallel flat slabs, referencing Gauss' Law and the concept of capacitors. Questions arise about the implications of this treatment on the electric field and energy calculations.
Some participants have suggested that the spherical configuration can be approximated as a capacitor, which may simplify the energy calculation. There is an ongoing exploration of whether integration is necessary for calculating the potential difference, with differing opinions on the need for this step.
Participants are considering the assumption that the electric field is constant within the region of interest, and there is a hint provided regarding the relationship between the setup and capacitor behavior.
wombat7373
Two concentric metal spheres have radii r_1 = 10 cm and r_2 = 10.5 cm. The inner sphere has a charge of Q = 5 nC spread uniformly on its surface, and the outer sphere has charge -Q on its surface. (a) calculate the total energy stored in the electric field inside the spheres Hint: You can treat the spheres essentially as parallel flat slabs separated by 0.5 cm why?
\phi = 4\pi kQ
U=qV/2
First of all, I don't know why treating the spheres as slabs will help, but since that's the hint, I'm looking for a way to do it. I can show with Gauss' Law that the electric field inside the inner sphere is 0, so that kind of makes them like slabs. Is that enough justification and why?
HINT: Think capacitors. How do you find the energy stored in a capacitor?
Two charged slabs separated by some distance d, is essentially a capacitor.
This is why treating the spheres as flat surfaces will help. The curvature will not really affect the situation, it is essentially a capacitor, whether spherical or flat.
I suppose I'll buy it just because the electric field ends up being constant like with two plates. So to find the energy I just do U=(1/2)QV. I suppose I could calculate the potential difference by integrating the electric field over that 0.5 cm distance. Would that be the way to do it?
I think its safe to assume that the field is constant within the capacitor. You shouldn't have to integrate, unless you want the practice of course:smile:
I would go about this using the formula for energy stored in an electric field, which is:
U = 1/2 C V^2
  • · Replies 22 ·
  • · Replies 36 ·
