Electrostatic Potential from a uniform line of charge?
The discussion centers on calculating the electrostatic potential and electric field from a uniform line of charge. The potential at a point on the x-axis, given by V(b) = (λ/4πε₀)ln(b/(b-a)), is derived by integrating contributions from infinitesimal charge elements along the line. The electric field E can be obtained from the potential using the relation E = -∇V, leading to E = (λ/4πε₀)((1/(b-a)) - (1/b)) for points where b > a. The results are consistent with the expected behavior of an equivalent point charge as b approaches infinity. The conversation emphasizes the importance of proper notation and integration limits in these calculations.
coffeem
a) What is the value of an electrostatic potential V, a distance r from a point charge Q?
b) A uniform line of charge, of linear charge density (\lambda), extends along the x-axis from x = 0, to x = a.
i) By considering the contributions from the infitisimal elements of the charge, show that the electrostatic potential at a point on the x-axis with x = b, where b>a, is given by:
V(b) = \stackrel{\lambda}{4pie0}ln(\frac{b}{(b-a)}
ii) Explain how the electrical field E can be derived from the distribution of the electrostatic potential.
iii) By considering how the potential varies with b, find the electrostatic field along the x-axis, again for b>a.
iv) Demonstrate that the value for E you have determined is consistant with that expected from an equivalent point charge, in the limit b>>a.
a) for this is simply have: v =Q/4pie0r.
b) I know that I am dealing with a continuous charge distribution problem here. But have no idea how I can show that... any advice would be appreciated. Thanks
Consider the line as a series of point-like charges, λdL each, where dL is the length of the charged line element. You know what is the potential of a point charge at a given distance. Integrate from L=0 to L=a all this contributions to the potential at the point x=b.
ehild
Since you have uniform linear distribution of charge, you know that linear density of charge is
\lambda=\frac{Q}{a}=\frac{dq}{dx},
where Q is total charge.
In order to find potential, you need to know electric field. Contribution of infinitesimal element is
d\vec{E}=\frac{1}{4\pi\epsilon_{0}}\frac{dq}{x^{2}}\hat{x}
(I assumed that charge is positive!)
On integration
\vec{E}=\frac{\lambda}{4\pi\epsilon_{0}}\int_{x-a}^{x}\frac{dx}{x^{2}}\hat{x}
\vec{E}=\frac{\lambda}{4\pi\epsilon_{0}}(\frac{1}{x-a}-\frac{1}{x})\hat{x}.
Then use the formula for potential and integrate again.
d\vec{U}=-\vec{E}\cdot d\vec{x}
Is this a definition of something which you have derived from the information given? I understand it, I just don't understand why it is dx rather than da?
On integration
OK so when I integrate over the limits from: b to 0. I get the correct answer so thanks!
Ok I am working through the rest of this question! However for part ii I have said we need to use the del operator on in the form E = -delV
However for the third part I think I just have to do the partial derivative in reference to b. However we are sort of just working back from the derivation... is this wrong? thanks
the charge density is 0 for x>a.
<br /> \vec{E}=\frac{\lambda}{4\pi\epsilon_{0}}\int_{x-a}^{x}\frac{dx}{x^{2}}\hat{x}<br />
equals to 0.
ehild
You can also solve this problem by finding the potential first.
dU=\frac{\lambda}{4\pi\epsilon_{0}}\frac{dx}{x}
U=\frac{\lambda}{4\pi\epsilon_{0}}\int_{b-a}^{b}\frac{dx}{x}
U=\frac{\lambda}{4\pi\epsilon_{0}}\ln\frac{b}{b-a}
\vec{E}=-\nabla U
to find electric field. It's maybe a bit harder, but you should get the same results.
For the iv) part you have
<br /> E=\frac{\lambda}{4\pi\epsilon_{0}}(\frac{1}{b-a}-\frac{1}{b})=\frac{\lambda}{4\pi\epsilon_{0}}\frac{a}{b(b-a)}.<br />
For b>>a
<br /> E=\frac{1}{4\pi\epsilon_{0}}\frac{\lambda a}{b^{2}}=\frac{1}{4\pi\epsilon_{0}}\frac{Q}{b^{2}}.<br />
Explain, please, what is x in your equations?
ehild
If you are referring to equation
<br /> U=\frac{\lambda}{4\pi\epsilon_{0}}\int_{b-a}^{b}\frac{dx}{x}<br />
x is the distance between infinitesimal charge and the point on x-axis.
I believe that this equation is confusing.
This is better
<br /> \vec{E}=\frac{\lambda}{4\pi\epsilon_{0}}\int_{x-a}^{x}\frac{dr}{r^{2}}\hat{x}=\frac{\lambda}{4\pi\epsilon_{0}}(\frac{1}{ x-a}-\frac{1}{x})\hat{x}<br />
x is a point on x-axis. I was trying to express the electric field in terms of x (any point on axis), so I can calculate the potential later by using the formula
<br /> dU=-\vec{E}\cdot d\vec{s},<br />
where s would be a vector pointing in direction where potential is smaller.
I hope it's better now.
Yes, the notation x is used for the x coordinate in the text of the problem. So the distance of a charge dq from a point at x is better be denoted with r.
Then the potential of the whole line charge at x is
<br /> <br /> U=\frac{\lambda}{4\pi\epsilon_{0}}\int_{x-a}^{x}\frac{dr}{r}<br /> =\frac{\lambda}{4\pi\epsilon_{0}}\ln\frac{x}{x-a}<br /> <br />
The integration is for the length of the line.
The lectric field is the negative gradient of U, and its x components is
E_x=-dU/dx=-\frac{\lambda}{4\pi\epsilon_{0}}\frac{x-a}{x}\frac{-a}{(x-a)^2}=\frac{\lambda}{4\pi\epsilon_{0}}\frac{a}{x(x-a)}for every x>a.ehild
