Dester
- 3
One type of ink-jet printer, called an electrostatic ink-jet printer, forms letters by using deflecting electrodes to steer charged ink drops up and down vertically as the ink jet sweeps horizontally across the page. The ink jet forms 30-μm-diameter drops of ink, charged them by spraying 800,000 electrons on the surface, and shoots them toward the page at a speed of 20 m/s. Along the way, the drops pass through two parallel electrodes that are 6.0 mm long, 4.0 mm wide, and spaced 1.0 mm apart. The distance from the center of the plates to the paper is 2.0 cm. To form the letters which have a maximum hieght of 6.0 mm, the drops need to be deflected up or down at maximum if 3.0 mm. Ink, which consists of dye particles suspended in alcohol, has a density of 800 kg.m^3
What amount of charge is needed on each electrode to produce this electric field
I know qE/m, I found m and q and also E via part A I solved, but now I'm stumped, can anyone give me hand?
