Electrostatic Self-Energy of a Uniform Density Sphere of Charge
The discussion focuses on deriving an expression for the electrostatic self-energy of a uniformly charged sphere with an arbitrary charge density distribution p(r). Self-energy is defined as the potential energy of a non-equilibrium charge system. The suggested expression for self-energy is Ws = 1/(4pi*epsilon0)*3/5*p(r)*V/R. To approach the problem, one can start with the general formula Ws = 1/2*q*V and analyze three scenarios based on the relationship between r and R. This method helps in defining constants needed for the expression when r is less than R.
harshey
Find an expression for the electrostatic self-energy of an arbitrary spherically symmetric charge density distribution p(r). You may not assume that p(r) represents any point charge, or that it is constant, or that it is piecewise constant, or that it does or does not cut off at any finite radius r. your expression must cover all possibilities. your expression may include an integral or integrals which cannot be evaluated without knowing the specific form of p(r).
I had no idea how to start this problem because i couldn't figure out what my professor meant by electrostatic self-energy of an arbitrary spherically symmetric charge density distribution.
Well, self-energy is potential energy of unbalanced charge system (in this case the sphere had just charged and not in equilibrium state).
Your answer:
You could start from general definition formula of Ws = 1/2*q*V, then calculate for 3 case: r < R, r > R, and r = R. The cases r = R and r > R help define constant C in case r < R.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
