Electrostatics - Work done by an electron
The discussion revolves around calculating the work done in moving an electron from 1nm to 10nm from a hydrogen nucleus. The initial approach uses the equation W=ΔU=qΔV, leading to a positive work result. However, there is confusion regarding the expected negative work due to the attractive nature of opposite charges at close distances. It is clarified that moving the electron requires applying a force in the positive x-direction, resulting in positive work since both force and distance are aligned. The conclusion emphasizes that the positive work reflects the energy needed to overcome the attractive force between the electron and the nucleus.
milkyway11
The problem states: how much work is done in moving an electron from a distance of 1nm to a distance of 10nm away from a hydrogen nucleus?
My attempt at the problem is using the W=\DeltaU=q\DeltaV. With this equation I would get a positive work. However, when I reason through the question, I would expect that it would have a negative work because I always thought the charges have more potential U when they are close to each other.
Could it be that the positive work is due to the unlike charges attract more at near distance and it takes more work to compensate the attractive force in order to separate them?
Thanks!
Consider a case where you're moving the electron in a straight line from a distance of 1nm to a distance of 10nm along the x-axis. Since the particles are attracting each other, you have to apply a force in the +x direction to do this. The distance that you move the electron is also in the +x direction. Since work is force dot distance (vector dot product), the work done by the force must be positive.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
