Elementary Linear Algebra Proof Basis/Dimension
Rockoz
Prove that if W is a subspace of a finite-dimensional space V, then (dimension of W) is less than or equal to (dimension of V).
I've been trying to prove this by contradiction (assume dimension of W is greater than V and arrive at a contradiction) but am a little unclear on how to write the proof out. Here is my attempt so far:
W is a subspace of V. Assume S is a basis for W. If span(S) = V then dim(W) = dim(V).
Otherwise let's assume that dim(W) > dim(V).
Let S = {V1,V2,...,Vn} be a basis for W. Let T = {V1,V2,...,Vk) be a basis for V where, because of our assumption, n>k (there are more vectors in the basis S than in T).
Here is where I'm not sure where to proceed. I'm trying to see where i can use the fact that S is a subset of V and compare the number of vectors in S and T but I'm just not seeing the answer. Please help me understand the next step conceptually. Thank you for your time.
From a purely logical viewpoint, you seem to make a leap here: "otherwise let's assume ...". You should draw an implication: "otherwise, we have that ..." or "otherwise, there is ...".
You are using a "proof by contradiction" so better wording would be "On the contrary, assume"... And, there is no reason to do dim(W)= dim(V) separately. Once you have shown a contradiction to "dim(W)> dim(V)", "less than or equal" follows.
And I would recommend being more "precise". "Let m be the dimension of V, n the dimension of W, with n> m." That means that there exist as set of n independent vector in W. Do you see how that contradicts m begin the dimension of V?
Thank you for helping me. It feels like this should be fairly simple but I'm having trouble writing out my ideas logically. Am I correct with my following reasoning?
Let m be the dimension of V, n the dimension of W, and assume n > m. This means there exists a set of n independent vectors in W. Since W is a subspace of V, this implies that there is a set of independent vectors in V larger than m. But this is impossible since every set in V containing more than m vectors must be linearly dependent. So n cannot be greater than m. Therefore it can only be true that dim(W) is less than or equal to dim(V).
Yes, that is perfectly good.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
