Proving Only 2 Positive Integer Solutions for x3 = y2 – 15
  • Thread starter Thread starter BenVitale
    Integer Positive
BenVitale
A problem asks to find all possible pairs (x, y) of positive integers that satisfy the equation:
x3 = y2 – 15
There are 2 pairs (so far) that satisfy the equation:
x = 1, y = 4
x = 109, y = 1138
It's possible that these 2 points are the only two positive integer solutions.
Siegel's theorem states that an elliptic curve can have only a finite number of points with integer coordinates.
Could there be other points for that curve? If not, how to prove that these 2 points are the only solutions?
Siegel's theorem does not help you here. You need to find a method that let's you set some kind of quantifiable limit on the ratio of something to something. Wikipedia references something called "Baker's method", which could be worth investigating. Then you'd prove that the points you found are the only solutions, by proving that there are no solutions above X, and by checking all points up to X manually.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
