How Do You Calculate the Flux of a Vector Field Through a Parametric Surface?
To calculate the flux of the vector field F = [x,y,z] through the parametric surface S defined by r(u,v) = [u cos v, u sin v, u^2], one must first determine the surface area element dA using the Jacobian of the transformation. The flux can be computed using the integral of the dot product of the vector field and the surface area element, expressed as flux = ∫(F · dA). It is important to correctly set the limits for the parameters u and v, which range from 0 to 2 and 0 to 2π, respectively. The discussion also highlights the need for clarity on whether the divergence of F is relevant to the problem. Understanding these concepts will ensure the correct approach to solving the flux calculation.
lazyluke
1. The expression F = [x,y,z] defines a vector field. Given the parametric representation of a surface S:[u cos v, u sin v, u^2] = r (u,v), where the parameters cover the ranges 0 ≤ u ≤ 2 and 0 ≤ v ≤ 2π, calculate the flux F through the surface S.
How do i start this problem?
I know the transformation equations for the cylindrical coordinates, and:
flux=Int(E dot dA=Int(divergence of E d tao
Im not sure if i should find the jackobian, but if so how do i work with the parametric representation vector r??
P.S. sry about spelling
Am i even in the right department with those questions?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
