EM Waves: Understanding their Composition and Mass [SOLVED]
Straight lines radiating out from a charge, I think of the force a charge would feel as it enters the electric field. When I think of a magnetic field I think of a bar magnet, and the shape of magnetic field lines. I don't think of a magnetic force, I think of the shape of the field. So what do you mean by changing electric and magnetic fields?In summary, EM waves consist of electric and magnetic properties and can be thought of as either a wave or a particle, depending on the experiment. They do not have rest mass, but their energy is shared between the electric and magnetic fields that they produce. These fields are constantly changing and produce a specific direction of movement. The curvature of spacetime caused
Farn
[SOLVED] EM waves
I have always been uncertain about what an EM wave consists of. I used to think it was a photon and somehow it carried properties of a wave. From reading some of the other posts on this forum, I'm realizing that I probably far off.
So what is it? Does it have mass? Electro-magnetic... I'd assume it has something to do with electrons, does it and how so?
Straighten me out people!
Kinda like this:
It has Electric and Magnetic properties. And and have wave or particle properties, but not at the same time.
It effects electrons has they have an electric charge.
you are correct. one can think of light as either a wave or a particle, this is called duality.
Does it have mass?
light has no rest mass. which basically means it has no mass. (which is obvious, because it could not accelerate to c if it did)
no, it has nothing to do with electrons. electro-magnetic was a term invented by Maxwell when he discovered light's shared properties of magetism and electricity. i think.
In addition to that said, I would add that the key to understanding EM at one level is to realize two things. First, if we do an experiment to detect light particles, we get particles. If we look for waves, we get waves. The experiment determines the nature of what we observe. This all relates to Heisenberg's Uncertainty principle; and from this we get the notion that the experimenter is an inseparable part of the experiment. We determine, or we select the reality by the way that we look.
The other thing to understand is how an EM wave is sustained. By the wave model, it starts as a change, for example, in the magnetic field strength of a wire or an antenna. But a change in a magnetic field also produces a changing electric field. As one field collapses, it produces the other. The energy of the photon is shared between these two fields. So really all we have are two changing fields that create the other, and that move in a specific direction as they do so.
Finally, I would also add that this notion that light has no mass is really a little misleading. A photon has no rest mass, but a photon is never at rest. It never has to "get to the speed of light". It can be argued that the mass of a photon is just hμ/C^2. Perhaps this approach fails at higher levels, but I believe this is consistent with General Relativity. Objections anyone?
Edit: Quickly I add, we do normally use the language the a photon has no rest mass; in spite of my personal objections.
Correct me if I am wrong, considering the fact that light is attracted to a black hole proves that light indeed has mass?
As far as what an EM wave is. Simply put Electricity and Magnetic waves of energy propigating through space. The electricity produces the magnetic when it is expanding and the magnetic is inducing the electric when it is collapsing. for ever and ever and ever until reactance of some sort stops it.
Like I said, to this extent I believe the model holds. I was alluding to greater complexities that QM, GUT, TOE, String, M or whatever may yield which could invalidate this as a proper interpretation.
Light is "attracted" to mass because a source of mass large enough distorts the very fabric of spacetime. Because light travels in a straight line, it looks as if it is curving to us 3d existing humans. But really light is just following the straightest path of curve spacetime. That's way gravitation lensing happens too.
Ivan, you mention a 'changing electric field' and a 'changing magnetic field' in your explanation. When I think of an electric field I think of electrons when I think of a magnetic field, I think of a current of electrons. However...as its been said an EM wave doesn’t require electrons to be present for it to propagate and of course this is true because we know they cross space. So I'm still at a loss for how these changing fields take place without electrons. What am I missing?
As I understand this [it's possible that I don't entirely], using the concept of the photon's mass yields the same result as calculating the deflection due to spacetime warpage. As stated, I believe that the concept of photon mass is consistent with GR. In the tensor, I don't think that the two approaches can be differentiated.
At the deepest levels, I am not qualified to answer this question correctly. To the extent that I can answer this I will try. Electrons have an electric field. The electron is one concept; the field is the other. It is not correct to think of the field as an extension of the electron. The field is a consequence of the internal workings of the electron - we would have to talk about quarks at this point and I'm not qualified to do so. But the key point is that the field and the particle are two different things.
Next, we get in deep quickly with Maxwell's equations and the implicit relativity theory therein. Maxwell tells us that an electric field is produced by a collapsing magnetic field. Also, as the electric field forms, it produces a magnetic field. This, at one level, is the best description of these two fields to be found. Anything else is just a less precise way of thinking about it. Also, each of these fields contains energy. The total energy of the photon could be found [in principle] by simultaneously measuring each field and then calculating and adding up the energies.
At another level, and I resist telling you this because it can easily cause confusion especially in this context, but, here we go. We do have a better explanation for the nature of these two fields. An electric field is just an exchange of photons! So, you seek to understand how the electric field manifests as a photon, and yet the photon IS the essence of the electric field. Honestly, I don't know how to explain the apparent contradiction. Perhaps someone else can help here. But it gets even worse.
Imagine that you are standing next to a wire in which current flows. As you mentioned, you could measure a magnetic field around the wire due to the flow of charge in the wire. Now, instead of a wire, imagine that we are talking about a stream of electron moving through a vacuum. Here comes the relativity part: If you could pace the flow of electrons moving through the vacuum by running alongside the stream of charge, the electrons would no longer appear to be moving. Correct? It would appear that they are motionless as compared to you. Guess what? If we have no moving charge, we don't have a magnetic field. Right? So when we started, you could measure a magnetic field as you stood next to the stream of electrons. But as soon as you start to move with the electrons, for you, the magnetic field disappears! A magnetic field is just an electric field viewed relativisticly!
Physics has the concept of fields existing in empty space (or "the vacuum"). This concept continues in modern quantum FIELD theory.
Photon are quanta (excitations) of the electromagnetiic field. Sometimes the photon is the appropriate way to analyze a given problem and sometimes the field is better.
EM is a perfectly good effective theory. At its own scale it gives accurate results, and in waveguides you can measure the sparate electric and magnetic components of the field coming down the pipe at right angles to each other.
Here's another thing. The Langrangian for quantum electrodynamics is made up of three terms added together. The first term is the lagrangian for Dirac's theory of the electron. The second term is the F[mu][nu]F[mu][nu] lagrangian for relativistic EM. The third term describes the interaction. In a free (no interaction) case, you have a separate - or no - electron and Maxwell's EM.
Hopefully this is not a stupid question; being a real wimp at QED it just ocurred to me : When we talk about photon exchange as the electric field, what determines the frequency of the photons? I would tend to assume that the electric field strength goes as photon frequency, but since classically the field strength depends entirely on the quantity of charge [assuming no magnetic field] present, which seems to mean that a stronger electric field has more photon exchanges but not stronger ones, I don't see what would detemine frequency of the photons. Photon enlightenment anyone?
exactly my point, if light had no mass it would not follow the curve.
First I'd like to say thanks for the many replies!
It’s been a little while since I first posted this, but as I read back over the responses there is one main question that pops into mind: What is a photon exchange, and how does it relate to an electric field?
One simple way to think of a photon exchange is to imagine that you and I are throwing baseballs at each other. This might be considered an analogy of a repulsive electric force - such as when two like charges repel each other. If I throw the ball, I get a little push as I throw the ball towards you. If you catch a ball, you get a little push from the ball. A photon exchange is kind of like this - like throwing massless baseballs [actually quanta of electromagnetic energy] at each other thus causing us move farther and farther apart. The actual situation is much more complicated but that's the idea.
It should be understood that this idea of a photon exchange is a more sophisticated idea than what is taught at least during the beginning semesters of college physics. Don’t allow this to confuse you when you hear other explanations for the electric field. One must remember that various scientific models can exist to explain the same thing. Each model is valid to within a certain level of precision, and given that certain criteria are met.
Until you begin to study Quantum Electrodynamics, not much of this can mean much. If and when you do study such subjects, it still won't mean much! You will just be learning how to manipulate the mathematics of a model that at the deepest levels we mere mortals really can't and may never understand.
I know this is a bit late but...
Photons travel at a speed which depends on the optical density of the substance through which they travel. It is only in a vacuum that photons travel at 3.0x10^8 m/s Just recently, some scientists did manage to completely freeze a beam of light within some device.
So...
Technically it is feasible to speak about the rest mass of a photon.
So...
I think you are misunderstanding the notion of slowing the speed of light. In the experiments to which you refer, what slows the apparent speed of light is the absorption and re-emission of photons. The average speed measured is then a function of the travel speed, coupled with the time for these absorptions and emissions. Also, the last that I checked, the slowest speed measured was about 3m/s. :smile:
Are you sure ?
Because I'm pretty sure I read an issue of New-Scientist that had an article about some guys who managed to fully freeze a beam of light. I could tell you which issue it was once I get back to university in August [?]
ps. Do you mean that light travels slower through water simply because the photons keep colliding with H2O which gets excited and releases new photons?
- I never really thought of it that way, and it makes quite a lot of sense... hmmm interesting
I am a little confused...EM waves are produced by moving (accelerating) electrons...Light is an EM wave, so that means light is just a visible form of EM wave which is produced by some form of acclerating electrons? Am I correct?
Are you sure ?
This is my understanding. Also, the equations for light do not allow this to happen. The nature of the photon is one of constant velocity - while a photon. It can only be absorbed and the energy conserved [stored], typically as an exited electron state, until re-emitted. It can also be absorbed and converted to heat energy.
I believe this is a correct way to think of it. Yes it is all very interesting!
Yes it would. Light travels in "straight lines" as reckoned in the spacetime in which they are moving. If the spacetime is curved, then the trajectory of the light will appear curved to us, despite the fact that light is massless.
edit: fixed a bracket
Yes; with the understanding that an EM wave packet [a photon] can be produced in other ways. For example, when an electron changes state from a higher energy to a lower one in an atom, a photon is released. Also, atomic collisions can produce photons. And of course, if matter and antimatter [edit: equal quantities of the two] come together all that we have left is photons [EM energy]
Wait a second, new thought...
If photons traveling through an optically dense
medium, were simply absorbed by atoms in the medium
and new ones were continually released, then surely the
new released photons would be released in some random
direction, and thus light would not travel in straight
lines when not in a vacuum?
We know that light travels in straight lines through
water glass or whatever, so where have we gone wrong?
See QED by Feynman. More complex processes manifest as the average condition that we perceive. I think in the end it is conservation of momentum that really saves the day here.
I know about QED and QCD and all that.
But I don't think they predict what
happens as far as the direction of the
released photon goes.
Can conservation of momentum still be applied
when there is no collision??
What we have here is annihilation (absorption)
and well as creation of a knew photon.
I may be able to answer this but I need to think about it. If anyone else LIKE TOM cares to comment please jump in.
Quantum Mechanically, momentum is conserved
at a collision eg. Compton Scattering.
With absorption and emission, there is a
time delay, in which the atom stays in the
excited state. So it is not a single collision
taking place. It appears that Momentum would
have to be conserved somehow, but the law of
conservation of momentum which holds for
collisions cannot be applied in this case.
Hey Tom, are you disputing the statement that I made, or just speaking withing the given context?
Not all of the photons have to absorbed and remitted. Some could pass in between the spaces between atoms and get to your eyes in a strait line, while some others are absorbed and remitted in a random direction(which could explain why the light seems to expand outward in all directions). And when you think about how many photons there are coming from source it's easy to see how so many can get away without being absorbed.
QED by Richard Feynman is a very insightful book, you need to find a copy. If you had read it you would not be asking these questions, as he addresses them directly.
Here is another recent thread which discusses this issue.
  • #31
Thanks, but if that is true, it does away with the reason of why this line of thought started being discussed here anyway.
The original question was:
Why do photons travel slower when traveling through an optically dense medium?
Ivan Seeking's suggestion was that they constantly get absorbed, and new ones are released, making the light beam travel slower.
I was simply arguing this.
1. What are electromagnetic waves?
Electromagnetic waves, also known as EM waves, are a type of energy that is created by the movement of electrically charged particles. They consist of both electric and magnetic fields that oscillate at right angles to each other and travel at the speed of light.
2. How are EM waves classified?
EM waves are classified based on their wavelength and frequency. The electromagnetic spectrum includes radio waves, microwaves, infrared radiation, visible light, ultraviolet radiation, X-rays, and gamma rays.
3. What is the composition of EM waves?
EM waves are composed of electric and magnetic fields that are perpendicular to each other and travel in a wave-like pattern. These waves do not require a medium to travel through and can travel through a vacuum.
4. What is the mass of EM waves?
EM waves do not have mass because they are made up of energy, not matter. They are considered to be massless particles and do not interact with the Higgs field, which is responsible for giving particles their mass.
5. How are EM waves used in everyday life?
EM waves have many practical applications in our daily lives. Radio waves are used for communication, microwaves for cooking, infrared radiation for remote controls and thermal imaging, visible light for vision, ultraviolet radiation for sterilization, X-rays for medical imaging, and gamma rays for cancer treatment.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Classical Physics
