Energy flux vector field problem is the isotherms are circles
doppelganger007
Suppose that the isotherms in a region are all concentric spheres centered at the origin. Prove that the energy flux vector field points either toward or away from the origin.
J = - k (del)T
so I know that -(del)T is perpendicular to the surface T, which is constant, but I'm not really sure how to finish off the proof from there...
You are given that " isotherms in a region are all concentric spheres centered at the origin." Suppose you are at a point (x,y,z) on such a sphere. At what angle does the line from (0,0,0) through (x,y,z) cross the sphere?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
