Energy needed to pull parallel plate capacitor
The problem involves a parallel plate capacitor with a capacitance of 10pF charged to 10kV and then isolated from the battery. The plates are pulled apart to a distance that is ten times greater than the original separation, and the energy required to perform this action is being questioned.
  • Participants discuss the effects of increasing the distance between the plates on the electric field, voltage, capacitance, and energy stored in the capacitor. There are attempts to relate changes in voltage and capacitance to energy calculations.
Some participants have provided guidance on how to approach the problem, suggesting that the relationship between capacitance, voltage, and charge should be considered. There is an ongoing exploration of how these variables interact as the distance changes, with some participants expressing confusion about the calculations and seeking clarification.
Participants are working under the constraints of homework rules, which may limit the amount of direct assistance they can receive. There is an emphasis on understanding the underlying principles rather than simply obtaining a solution.
kishor7km
a parallel plate capacitor of 10pF is charged to 10kV ( air dielectric). It is then isolated from battery.The plates are pulled away from each other until distance is 10 times more than before. what is the energy needed to pull the plates.
c=εA/d ; c=Q/V ;
You will get more help if you show some attempt at the problem, or at least give us an idea of what part you are struggling with. People don't want to just give you the answers to your homework.
Hi CanIExplore,
Thanks for your advice.
3. The Attempt at a Solution ::
I assume, the electric field will not change if distance between plate increase, but voltage will do.
Voltage, V =Ed
So If d -> 10d, V=E*10d = 10V .
So New Energy, W2=1/2 * C * V ^2 = (10^2)W1 . ( W1 is energy stored before modification)
Is this correct?
What will happen to capacitor,C if the distance(d) increases?? Whether both capacitance and voltage will change?? I know C=Q/V ;
So how to calculate energy in this case?? I am little confused... Please help
kishor7km said:
... What will happen to capacitor,C if the distance(d) increases?? Whether both capacitance and voltage will change?? I know C=Q/V ;...
To find what happens to C it is better to look at C = \epsilonA/d
Ok. So in this case capacitance becomes 0.1C, right??
hence the energy stored in the capacitor(after pulling the plates) will be 10 times more than that of initial condition.
My solution is,
First case: Energy,W1 = 1/2 * C * V^2
= 1/2 * 10pF * (10kV)^2
= 0.0005 joules
Second case: after plates are pulled away 10 times
Energy,W2 =1/2 * (0.1*10pF) * (10*10kV)^2
= 0.005 joules
So the energy required to pull the plates is = W2 - W1
= 0.0045 joules.
Is it correct? or am I missing something?? because this answer is not there in available choices.
I think it is correct.
One can look at it from another angle.
Voltage, V =Ed
This is exactly right.
Well you've already stated that the voltage will change. You just found how much it changes when the distance is increased in the previous part. Then according to the definition of capacitance which you have written there, how does the capacitance change if the voltage changes?
To find the work, try writing your work equation in terms of just voltage and charge, or just capacitance and charge rather than having both of them in your equation at once.
@ grzz and CanIExplore,
thanks for your help guys.
I think now I got the clear idea..thanks again for your time.
Exactly. That was the other point of view that I had in mind. It is very conventient to have only one variable to deal with. Hence it is profitable to involve the charge because since the capacitor is isolated this charge remains constant.
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 58 ·
