Preserving Heat Energy from Fridges: Alternatives & Ideas
The discussion revolves around the challenge of converting heat energy dissipated from refrigerators into electrical energy for powering sensors and indicators. Participants express skepticism about the efficiency of such conversions, noting that the temperature difference is often too small to yield significant energy. One suggested method involves using a piston system that expands and contracts due to the heat, driving a dynamo to generate electricity. However, concerns are raised about the trade-off between efficiency and the operational effectiveness of the fridge itself. Overall, while ideas are shared, the consensus is that the conversion process may not be practical or cost-effective.
Apache
How can I preserve energy dissipated out from some devices that always extract heat like fridge?
Do you guys have some alternatives or ideas to convert heat energy to electrical energy that can supply some sensors and indicators?
Thanks!
Your question looks a bit unclear to me. What do you mean with "preserve energy"?
Energy is conserved, and if you cool one object, you have to heat another object due to entropy.
If you don't need much power and just want to save cables: Thermocouples?
I mean convert the heat dissipated out from device to other form of energy and used for other purposes. Normally we just treat them as heat loss because temperature is too low and it is not much efficient to be converted. So now I am trying to convert heat dissipated from condenser of fridge to electrical energy.
I was thinking like making the air inside a piston to expand after heating by heat dissipated out from condenser under constant pressure.
Under expanding and contracting of piston, the piston drive a simple crank and thus drive a dynamo.
The dynamo then save energy to supply some low voltage, low current drawing electrical elements like thermostat and sensors.
My fundamental in heat is not strong.
Looking forward to some advices. =)
You can get a small fraction of that, but the process cannot be very efficient (in absolute numbers) as the temperature difference is small. Even worse: to make it more efficient, you have to make the fridge less efficient. You cannot win that game, and basically everything is too expensive if you just get something like 1W (-> 9kWh per year).
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
