Energy, time and length corresponding to mass of electron.
H_Psi
Hey,
I am starting to learn the basics of QED and I am trying to get acquainted with the units and scales that are used.
The exercise is to estimate the energy, time and length that correspond to the mass of an electron.
That’s what I did:
The mass of an electron is 9.11E-31 kg.
Energy:
E=mc^2 gives me an energy of 0.511MeV.
Length:
Here I used the equation: c * hbar = 197 MeV * fm
-> 386fm = c * hbar / (0.511MeV)
-> In natural units: 386fm = 1 / (0.511MeV)
Time:
Here I used the equation: hbar = 6.58E-22 MeV * s
-> 1.288E-21 s = hbar / (0.511MeV)
-> In natural units: 1.288E-21 s = 1 / (0.511MeV)
Is this calculation correct? Is that the way one can calculate the length and time corresponding to a mass?
Thanks
Makes sense, but I'd take a look at the equation you used to find the length. Do you really want to be using the reduced Planck constant (hbar) there, or simply the Planck constant (2*pi*hbar)? You can look up the de Broglie wavelength of an electron, and you'll see your value is a bit small.
That depends on the convention, right? For instance, in Peskin, the convention is to use hbar as the base unit (of action). I don't recall seeing anyone use just plane h as the base unit, but it is just a convention.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
