Engineering Dynamics Problem
In summary, a 5000-lb truck is trying to lift a 1000-lb boulder and a 200-lb pallet using a pulley system off a cliff face. With no friction, the sum of forces on the truck and the pulley system can be set up to determine the horizontal force between the truck and the ground. However, the provided solution of 765-lb may be incorrect due to a possible error in the given information.
rdg29
1. Problem statement:
A 5000-lb truck is being used to lift a 1000-lb boulder B that is on a 200-lb pallet. Knowing the acceleration of the truck is 1 ft/s^2, determine the horizontal force between the tires and ground. The truck is on a horizontal plane with the boulder and pallet connected to a single pulley system off a cliff face.
:[/B]
∑F = ma
3. Attempt at the solution:
[STRIKE]Assuming no friction.
[/STRIKE]
First, I separated the truck and the boulder with two separate FBD/Kinematic diagrams.
For the truck, I had 4 total forces acting on the body.
F = ? (horizontal force between the truck and the ground)
T = ? (tension in the cable)
N = 5000 lb
W = -5000 lb
Setting up the sum of the forces on the truck, we get:
∑Fy = 0
∑Fx = F - T
(ma)sum = F - T
mtruck = 5000/32.2 = 155.280
Subbing in the known values:
155.280*1 ft/s^2 = F - T
Now, I moved to the pulley system:
The FBD consisted of 3 forces:
Wb = Weight of the Boulder = 1000 lb
Wp = Weight of the Pallet = 200 lb
Setting up the sum of the forces, we get:
∑Fx = 0
∑Fy = T - Wb - Wp
mboulder+pallet = (1000 lb + 200 lb)/32.2 = 37.267
(mboulder+pallet*1 ft/s^2) = T - 1000-lb - 200-lb
T = 1237.267-lb
Use T to find F in the equation for the truck:
155.280 = F - 1237.267
F = 1392.5-lb
The problem I am running into however, is this does not match the answer I'm told to find. I'm wondering if it is just something simple that I'm missing here, so any guidance would be appreciated.
Looks ok to me except you should found off the number. There is friction,though, between driving tires and road. Otherwise, the truck couldn't move.
Thanks for looking it over, and pointing out the friction error on my part. The overall error may end up being an error in the solution provided maybe? The solution listed is 765-lb for the force between the ground and the truck.
Must be a book error .
Hi there,
Thank you for providing a detailed attempt at solving this engineering dynamics problem. It seems like you have set up the equations correctly and have made good progress in solving for the horizontal force between the truck and the ground.
One thing that may be causing the discrepancy between your answer and the expected answer is the assumption of no friction. In real-world situations, there will always be some level of friction present, especially in a pulley system. This could potentially affect the calculations and lead to a slightly different answer.
I would also recommend checking your units throughout the problem to ensure that they are consistent. For example, in your final calculation, you have used pounds (lb) for the weight of the boulder and pallet, but used the unit foot per second squared (ft/s^2) for the acceleration. This could potentially lead to an incorrect answer.
Overall, your approach to solving the problem seems sound and I would suggest double-checking your calculations and taking into account any potential sources of error, such as friction. I hope this helps and good luck with your future engineering problems!
1. What is Engineering Dynamics Problem?
Engineering Dynamics Problem is a branch of engineering that deals with the study of the motion and forces of objects. It involves analyzing the behavior and motion of systems under the influence of external forces and how these forces affect the motion of the system.
2. What are some common applications of Engineering Dynamics Problem?
Engineering Dynamics Problem has a wide range of applications in different fields such as aerospace, mechanical, civil, and biomedical engineering. Some common applications include analyzing the motion of vehicles, designing structures to withstand forces, and studying the movement of human body parts.
3. What are the main principles used in Engineering Dynamics Problem?
The main principles used in Engineering Dynamics Problem include Newton's laws of motion, conservation of energy, and conservation of momentum. These principles help in understanding and predicting the behavior of objects under the influence of forces.
4. How do engineers solve Engineering Dynamics Problems?
Engineers use mathematical models and equations to solve Engineering Dynamics Problems. They also use computer simulations to analyze complex systems and predict their behavior under different conditions. Engineers also rely on their knowledge of physical principles and apply them to real-world problems.
5. What are the key skills required for solving Engineering Dynamics Problems?
The key skills required for solving Engineering Dynamics Problems include a strong understanding of mathematical concepts, critical thinking, and problem-solving skills. Engineers also need to have a good grasp of physical principles and the ability to apply them in real-world situations. Additionally, proficiency in computer simulations and data analysis is also important in solving Engineering Dynamics Problems.
  • Mechanical Engineering
