Engineering equivalent to ArXiv?
There is currently no open access archive for engineering topics that is equivalent to ArXiv. A suggestion was made to use Vixar.org, but it lacks quality control, resulting in lower submission standards. Participants noted that while Vixar allows for preprints, it does not ensure the quality of content. Other resources like Google Books, Google Scholar, and Wikipedia were mentioned, but they do not specifically cater to engineering. The discussion highlights a gap in the availability of a reliable engineering preprint repository.
Aaronvan
I'm wondering of there is an open access archive of engineering topics, similar to ArXiv. Does anyone have any information?
Try http://vixar.org (spells like arxiv but backward). It is functionally equivalent.
Ludwik Kowalski (see Wikipedia)
http://csam.montclair.edu/~kowalski/life/intro.html
Not functionally equivalent. The site you mention does not screen for quality, so the intelligibility and coherence of the submissions are, on average, lower than arXiv. I wouldn't recommend that anyone go there for engineering-related information.
Unfortunately, I don't have an answer to the OP's question, other than to suggest the obvious: Google Books, Google Scholar, eFunda, Wikipedia.
It also doesn't cover engineering. To my knowledge, there is no ArVix equivalent for engineering.
You are correct. There is no quality control; anyone can post what they want. By "equivalent" I meant a site at which one can store preprints, or unpublished papers.
Maybe someone will fill that space then.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
