Engineering mechanics friction question HELP PLEASE
The discussion revolves around a friction problem in engineering mechanics involving two blocks, A and B, with specific masses and coefficients of friction. The user struggles to determine the necessary force P to initiate motion, having calculated various forces but feeling uncertain about their approach. Guidance is provided to draw Free Body Diagrams (FBDs) for both blocks to clarify the forces at play, emphasizing the importance of understanding friction direction based on motion. The user eventually finds the correct answer but remains confused about the direction of friction forces. The conversation highlights the necessity of clear problem-solving steps in mechanics to avoid common errors.
weihong892
engineering mechanics friction question! HELP PLEASE!
I need help for this question, please help me. i can't get the right ans. ):
6.2) Block B rests on block A and is attached by a horizontal rope BC to the
wall as shown in Figure-2. What force P is necessary to cause impending motion
of A? The coefficient of friction between A and B is 0.25 and between A and the
floor is 0.33. A has a mass of 14 kg and B has a mass of 9 kg. ( P= 102.7 N)
Welcome to PF! If you show an attempt at your work (which is a requirement in this forum), someone will be better able to assist, to see where you may have gone wrong. Be sure to calculate normal forces correctly.
okay, but i don't know my step are correct anot, but i can't get the ans.
sum of x = 0
sum of x = -Px - (9 x 9.81 x 0.25) + c + (23 x 9.81 x 0.33)
= -Px - 22.0725 + c + 74.4579
= -Px + C + 52.3854
Px = C + 52.3854
Sum of y = 0
Sum of y = Py + Nb + Na - (9.81 x 9) - (14 x 9.81)
= Py + 88.29 + 225.63 - 88.29 - 137.34
= 88.29 + Py
That all i do, and i am stuck, correct me if i am wrong. please.
You are not drawing Free Body Diagrams (FBD's) correctly, and you have signage errors. You might want to start off by first isolating the top block B, using a FBD to note all forces acting on it. By doing this, and looking in the y direction, the normal force on B acts up, and is equal to the 88 N you calculated correctly.
Now draw a FBD of the bottom block A. Which way does Nb act on A? (think of Newton's third law). What other forces act on A? (the tension force c is not one of them).
Now use Newton 1 in the y direction and x direction to solve for P, looking at Block A only. Note that friction forces oppose the direction of relative motion between surfaces.
i still have problem drawing the FBD of block a. ): how many forces are there?
nvm, i got the answer already. but i got a part i dun understand. is Fb pointing to the left? why issit pointing to the left but not the right?
If by Fb you mean the force of friction between A and B, well, if Block A wants to move left, then the friction force of B on A must point right, (the same as the direction of the friction force of the floor on A).
If you're looking at Block B, however, Newton 3 tells you that the friction force of A on B must point_____?
You haven't shown how you arrived at the correct answer.
