Entropy Question: Calculating Entropy Change for a Diamond
  • Thread starter Thread starter Jerzey2Atl
    Entropy
The discussion focuses on calculating the entropy change for a diamond when heated at constant volume from 10.0 K to 350 K, using Debye’s law for molar heat capacity. The relevant equation for molar entropy change, ΔS, is provided, which involves integrating the heat capacity over temperature. The user seeks clarification on the appropriate form of the entropy equation to apply and confirms the need to calculate the number of moles based on the diamond's mass. The molar mass of carbon is noted as 12.0 g/mol, which aids in this calculation. The thread emphasizes the importance of correctly applying thermodynamic principles to determine the entropy change.
Jerzey2Atl
Hi, this is my first time using this forum. I have a question dealing with entropy and thermodynamics.
Here goes:
According to Debye’s law, the molar heat capacity at constant volume of a
diamond varies with temperature according to the relation
Cv = (12*pi^4*R / 5) x (T / TD)^3
where TD = 2230 K. For a diamond of mass 1. 20 g, what is its entropy change when it is heatedat constant volume from 10. 0 K to 350 K? The molar mass of carbon is 12. 0 g/mol.
I know Ih ave to first find the molar mass, but I am not sure of which form of the entropy equation to use. Any help is appreciated.
To solve the problem you can use this equation to find the molar entropy
\Delta S = \int_{T_1}^{T_2} C_v \frac{dT}{T}
Multiply this result by the numer of moles (1.2/12) to get entropy in terms of energy/time.
Thanks a lot...imma try this.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
