Equation for lines that are tangents to a circle
  • Thread starter Thread starter df606
    Circle Lines
The discussion focuses on deriving a differential equation for straight lines tangent to the circle defined by the equation x² + y² = a², where 'a' is a constant. The user initially proposed the equation y = ±(b(x + b)/√(a² - b²) + √(a² - b²)), which simplifies to y = ±(bx + a²)/√(a² - b²). After exploring the differentiation of the circle's equation, they concluded that the correct tangent line can be expressed as y = xy' ± a√((y')² + 1). Ultimately, the user resolved their confusion by adjusting their approach to the problem.
  • Understanding of differential equations
  • Familiarity with the geometry of circles
  • Knowledge of calculus, specifically differentiation
  • Ability to manipulate algebraic expressions involving square roots
  • Study the derivation of differential equations from geometric shapes
  • Learn about the properties of tangent lines to curves
  • Explore the application of implicit differentiation in calculus
  • Investigate the use of parametric equations in describing curves
Students studying calculus, particularly those focusing on differential equations and geometry, as well as educators looking for examples of tangent line derivations related to circles.
df606
Find a differential equation whose solution is a family of straight lines that are tangents to the circle x^2+y^2=a^2 where a is a constant.
So actually I'm stuck on the first part, coming up with such an equation. After some work I came up with
y=\pm(\frac{b(x+b)}{\sqrt{a^{2}-b^{2}}}+\sqrt{a^{2}-b^{2}})
(b varies from -1 to 1 to produce the different straight lines)
which reduces to
y=\pm\frac{bx+a^{2}}{\sqrt{a^{2}-b^{2}}}
and finding a differential equation whose solution is this family of straight lines is making my head hurt. Before I keep working I want to make sure this looks right. Graphing the equation works, but perhaps I'm misunderstanding the question.
This is different to the equation I obtain. I first started by differentination of the circle equation to obtain:
<br /> \frac{dy}{dx}=-\frac{\alpha}{\beta}=\pm\frac{\alpha}{\sqrt{a^{2}-\alpha^{2}}} <br />
The above is the tangent of the line hitting the circle at the point (\alpha ,\beta ), now what you have to do is construct the line with the above tangent vale to get the equation of the tangent line.
They could just mean, differentiate the equation of a circle twice?
The answer is
y=xy&#039;\pm a\sqrt{(y&#039;)^2+1}
I wish I could just differentiate twice cause that makes things so much easier but I can't.
I used the equation you got as the slope for my line. That gives you a line that has the right slope but it doesn't intersect the circle at the right spot. The extra stuff in my equation moves the line around so it intersects the circle when their slopes are equal. I guess what I should be asking is, is that necessary? I'll try using the equation without extra stuff attached to it and see what I get.
Edit: Never mind, I got it, the formula was right, I was just going at it with the wrong approach. I kept squaring both sides to get rid of the ± because of some phobia I have of them, and once I stopped doing that, the problem became much simpler. I realized this after six pages of work...
