Equation for the tension in the string
  • Thread starter Thread starter Gughanath
    String Tension
The discussion revolves around calculating the value of k in a pulley system with two masses, 3m and km, where A accelerates at 2/5g. The initial calculation yielded k as 1.29, but it was clarified that k must be greater than 3. Participants confirmed that if km is greater than 3m, A would accelerate upwards, leading to a revised calculation of k as 7. The importance of correctly interpreting the problem's conditions was emphasized, resulting in a clearer understanding of the relationship between the masses and acceleration. The final consensus is that k should indeed be greater than 3, confirming the revised value.
Gughanath
Two objects A and B hang down on either side of a smotth pulley, connected by an inextensible string. The masses of the objects are 3m and km respectivly. A accelerated at 2/5g when released. g=9.8N. What is the value of k.
I worked it out to be 1.29, by writing an equation for the tension in the string for both objects. But the the value of k is supposed to be greater than 3. :confused: Did I use the wrong method?
What direction does A accelerate? You assumed down, and got the correct answer for that assumption. If km > 3m, then A would accelerate up. Try making that assumption and solve for k.
yes. This time round I get k=7? Is this right?
Oh right. I didnt read the question properly. if k is bigger than 3, then obviously its the greater mass. Thanks for clearing my problem.
