stupidkid
- 18
PHP:
Solve for x:
x^2+x^2/(x+1)^2=3
I got the final equation but I am unable to get the it form there.
x^4-x^2+2x^3-6x-3=0
Solve for x:
x^2+x^2/(x+1)^2=3
x^4-x^2+2x^3-6x-3=0
stupidkid said:Is there a actual way to solve these type of sums! PLS I NEED HELP I AM DUMB.
The purpose of equation homework problems is to test your understanding and application of mathematical concepts and equations.
To solve an equation homework problem, you need to first identify the given variables and the unknown variable. Then, use algebraic operations to manipulate the equation until the unknown variable is isolated on one side of the equal sign.
Common mistakes to avoid when solving equation homework problems include forgetting to distribute terms, making calculation errors, and not following the correct order of operations.
You can check your answer to an equation homework problem by plugging it back into the original equation and seeing if it satisfies the equation. You can also double check your calculations and make sure you followed the correct steps.
There are many resources you can use to help you solve equation homework problems, such as textbooks, online tutorials, and asking your teacher or peers for assistance. You can also use a calculator or online equation solver to check your work.
