Equation is a parabola with a vertical axis of symmetry
For the equation Ax^2 + Cy^2 + x + Ey = 0 to represent a parabola with a vertical axis of symmetry, A must be non-zero, C must equal zero, and E must also be non-zero. If A equals zero, the equation becomes linear, while if C is non-zero, the parabola cannot maintain a vertical axis. The constant E cannot be zero, as this would imply the parabola passes through the origin, which contradicts the requirement for a vertical axis. Therefore, the correct restrictions are A cannot equal 0, C must equal 0, and E cannot equal 0. This ensures the equation maintains the necessary characteristics of a vertical parabola.
gillgill
Determine the restrictions on the constants A, C and E such that the following equation is a parabola with a vertical axis of symmetry.
Ax^2+Cy^2+x+Ey=0
a) A=0, C cannot=0, E cannot=0
b) A=0, C cannot=0, E=0
c) A cannot=0, C=0, E=0
d) A cannot=0, C=0, E cannot=0
i know that A cannot=0 and C=0...how about the x and y...what do they have to do with axis of symmetry?
Here's how you should not do it (I think):
If C is zero you can immediately see you have the equation of a parabola with a vertical axis of symmetry. (This eliminates two answers)
Suppose c) is the answer. It's obvious you don't have a parabola.
So one answer remains.
BTW: A parab. with a vertical axis of symmetry has the form y=a(x-b)^2+c
The correct answer is d) A cannot=0, C=0, E cannot=0.
In order for the equation to be a parabola with a vertical axis of symmetry, the coefficient of the x^2 term (A) cannot be equal to 0 because this would result in a linear equation. Additionally, the coefficient of the y^2 term (C) must be equal to 0 in order for the parabola to have a vertical axis of symmetry. This is because a parabola with a vertical axis of symmetry has a constant x-value for every y-value, meaning there is no variation in the x-value.
The constant term (E) cannot equal 0 because this would result in a parabola that passes through the origin, and a parabola with a vertical axis of symmetry does not pass through the origin. It must have a vertex that lies on the y-axis.
In summary, the restrictions on the constants A, C, and E for the equation to be a parabola with a vertical axis of symmetry are: A cannot equal 0, C must equal 0, and E cannot equal 0.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
