Equilateral triangle coulombs law problem
The discussion revolves around calculating the force on charge q2 in an equilateral triangle configuration with three charges. The main equation used is Coulomb's Law, F = k * q1 * q2 / r^2, to find the forces between the charges. Initial calculations yielded a force of 3.05 microcoulombs, but it was later corrected to 3.05 Newtons. Participants emphasized the importance of accounting for angles between the forces and suggested simplifying calculations by recognizing symmetry in the forces acting on q2. The conversation highlights the need for careful consideration of both magnitude and direction in vector addition when solving such problems.
physicskid72
1.) Three charges are placed 25 cm apart in an equilateral triangle. Q1 has a charge of -6.0 nC, q2 has a charge of 4.0 nC and q3 has a charge of 4.0 nC. what is the force on q2?
q1 is the top point, q2 is the bottom left leaving q3 on the bottom right
F = K q1q2/r^2
Fnet2 = F12 + F32
using the above equation for f12 i get: 3.45 * 10^-6
components:(3.45 * 10^-6) sin60 = 2.99 * 10^-6 North
:(3.45 * 10^-6) cos60 = 1.72*10^-6 East
F32 using the equation above = 2.3 *10^-7 West
combining the x components = 5.81 *10^-6 West
so using pythagoras: Root((5.81 * 10^-6)^2 + (2.99*10^-6)^2))
= 3.05 * 10 ^-6 C
angle= arctan((2.99*10^-6/ 5.81*10^-6))
= 79 degrees North of west
so my final answer is 3.05 mirco coulombs (79 degrees N of W)
Is this correct? I want to make sure i have a grasp on these problems before my final exam on the 18. Any help is greatly appreciated!
i used 10^-9 and meters, and i see i made a mistake in the answer it should be 3.05 Newtons not micro coulombs.
OK firstly I'd say that drawing a quick diagram really helps with visualising a problem like this. Here's one if you don't have one already http://yfrog.com/e4pf3ij
:smile:
Using that equation:
F=\frac{k.q_{1}.q_{2}}{r^{2}}
You can indeed work out each of the forces, i.e. of each charge on each other charge, as you've done already.
So..
F_{1 on 2} = \frac{k\times (-6)\times {4}}{(25)^{2}} = \frac{-24k}{625}
Then you need to account for the angle between them (since not on a straight line) so should actually be:
F_{1 on 2} = \frac{-24k}{625}sin(30)[/itex]<br /> <br /> Then you can use the same method to calculate F_{3 on 2} noting that the angle between them is 0 i.e. don&#039;t need to account for an angle between these.<br /> <br /> Hopefully this helps a bit more <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />
Just to add that you should find that F_{2 on 3}=F_{3 on 2} so that you only need to worry about the components F_{1 on 2} and F_{2 on 1}.
Also you can simplify the calculations using that sin(30)+sin(60)=\frac{1+\sqrt{3}}{2} and that \frac{kq_{1}q_{2}}{r^{2}} components of both are equal.
Hence you should be able to work out the resulting force on charge q_{2}
okay I am slightly confused, why did you use 30 degrees instead of 60? and is my overall answer correct?
Ok..
Shouldn't it be:
F_{1 on 2}=\frac{k\times q_{1}\times q_{2}}{r^{2}}=\frac{(9\times10^{9}N.m^{2}.C^{-2})(-6.0\times 10^{-9}C)(4.0\times 10^{-9}C)}{(25m)^{2}}=-3.45\times 10^{-10}N
Then account for the angle between them, so:
F_{1 on 2}=-3.45\times 10^{-10}sin(30)N = -1.73\times 10^{-10}N
Also, since F_{3,2}=F_{2,3} then these forces just cancel each other out right.
Then the other force to consider:
F_{2 on 1}=\frac{k\times q_{2}\times q_{1}}{r^{2}}=\frac{(9\times10^{9}N.m^{2}.C^{-2})(4.0\times 10^{-9}C)(-6.0\times 10^{-9}C)}{(25m)^{2}}=-3.45\times 10^{-10}N
Then account for the angle:
F_{2 on 1}=-3.45\times 10^{-10}sin(60)N = -2.99\times 10^{-10}N
Therefore the force on q_{2} is:
F=4.6\times 10^{-11}N
Well, that's what I've just got anyway. Your whole method is a bit different. Hopefully that's clearer now :smile: (for both of us, was getting bit confused as well :wink:)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
