Calculating pH of Buffered Solutions: Do You Need a Ka/Kb Value?
  • Thread starter Thread starter Dpasi314
    Equilibrium Ph
The discussion centers around the challenge of calculating the pH of a buffered solution in AP Chemistry, specifically for the solution containing 0.50 M C2H5NH2 and 0.25 M C2H5NH3Cl. The original poster expresses confusion about how to determine the pH without given Ka or Kb values. Responses suggest that the necessary Kb value can often be found through a quick online search or may be provided in a pKa table in textbooks. The importance of knowing the chemical identity of the species involved is emphasized as a key step in finding the required values for the calculation.
Dpasi314
Hello,
So as the end of the year comes to an end, AP Chemistry is getting increasingly more difficult to the point where I don't understand anymore. In our homework there is a questions asking to calculate the pH of a buffered solution. The only information it gives you is the chemical formula and the molarity. i.e
Calculate the pH of each of the following buffered solutions:
a. 0.50 M C2H5NH2/0.25 M C2H5NH3Cl
I'm not quite sure how I'm suppose to be able to figure out the pH without having a Ka/Kb value given? Is the question assuming that I need to know what the Ka/Kb value? Or am I missing something entirely?
Thanks for the help!
Chemistry news on Phys.org
Hi Dpasi314. Welcome to Physics Forums.
Do you know the name of the 0.5 M species? If so, have you tried Googling it? It should take less than a minute to find the Kb.
Chet
Perhaps you were given a pKa table? Or there is one in your book?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
