Equilibrium Temperature of water in cup
The discussion focuses on calculating the equilibrium temperature of a system consisting of an ice cube, water, and an iron cup. Participants highlight the importance of using the correct specific heat capacities and latent heat values in the calculations. The initial attempt at the solution was flawed due to incorrect conversions and missing terms, particularly regarding the melting ice and the warming of meltwater. It is emphasized that the temperature change factors should reflect that the water and cup are cooling down while the ice and meltwater are warming up. A revised approach is suggested, incorporating all relevant terms to accurately solve for the final temperature.
Rayvin
A 37 g ice cube at 0.0°C is added to 110 g of water in a 62 g iron cup. The cup and the water have an initial temperature of 40°C.
(a) Find the equilibrium temperature of the cup and its contents.
I think a relevant equation is (m Lsubf) + (mc delta T) + (mc delta T)
I am completely lost, I started out (.110kg)(4.186 j/ kg c) (T-40) + (.037)(2090 j/ kg c)(T-0) + (.062) (448 j/kg c) (T-40) , I think I have most the units correct, I just don't know the correct equation for the problem or maybe what to do with all the units. Help please, am I using the correct equation? am I missing units? What is L sub f ?
I added the like units and mutiplied them then divided by T value to get T:
(.209kg)(2542.186 j/kg c)/80 and got T= 6.64 C. This came up as incorrect and I was wondering if anyone could tell me what I did wrong?
Your equation looks right:
= 0
solve for T.
I think you have converted some of your heat capacities and not others: iron would be 448 j/kg c, but then water must be 4186 j/kg c .
I take it that the 2090 j/kg c is what you are using for the latent heat of fusion (or melting of ice). The process of melting the ice is a phase transition which occurs at constant temperature 0 C, so there shouldn't be any temperature factor there. But also, the latent heat should be 334,000 j/kg , no, since it's 80 cal/gm? (You don't need a warming term for the ice, since its initial temperature is given as 0 C.)
You are also missing a term: the 37 g of meltwater from the ice will be warming up from 0 C, so you need a (.037)(4186 j/kg)(T - 0) to account for that.
If you set up the calorimetry equation with all the terms on one side, don't forget that the ice is warming up, but the water and iron cup are *cooling down*. The temperaure change factors would have to be written as (T final - T initial).
You'll need to rewrite your equation in this light and try solving it again.
