Equivalent circuit for non linear capasitor
The discussion focuses on determining the equivalent circuit for a non-ideal capacitor, specifically a parallel plate capacitor filled with a conductive and permittive material. Key considerations include the effects of resistance, inductance, and capacitance in the system, as well as the potential for hysteresis and non-linear behavior. The conversation highlights that the first approximation of a capacitor involves an ideal capacitor with a series resistance, known as effective series resistance (ESR), and a parallel resistor to model leakage current. Additionally, at high frequencies, inductive effects may need to be accounted for with a series inductor. Understanding these factors is crucial for accurately modeling the behavior of non-linear capacitors.
EHT
what is the equivalent circuit for a non ideal capasitor?
and if we have a parallel plate capasitor which consist of 2 metal plate of area A and held a distance apart d,we fill the region between the plate with a material with conductivity s and permitivity e.what is the inductance,resistance and capasitance of this system?
thanks
Welcome to PF!
Hi EHT! Welcome to PF! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
A partial list of the so-called elementry circuit elements, that I recall, are: voltage source, current source, R, L, C, and gyristor. --don't know much about this topic. The voltage source can be scratched if we can replace it with an infinite capacitor with initial charge. Same argument goes for the current source, replaced with an L-->infinity inductor and finite initial current.
The question, as you stated it is very broad. Can there be hysteresis? Can C be a function of time? Is C a monotonic function of V or I?
The most general condition I can think of off hand (ignoring probabliliy functions) is that C is a relation on t, V and I.
Your description suggests a device that is linear. In what way is it non-linear?
Yeah, I missed that, marcus.
The first approximation of a capacitor is an ideal capacitor with a series resistor. This is quoted in the data sheets are ESR, effective series resistance. The leakage current, considered as a function of voltage, models as a resistor in parallel with the ideal capacitor. At high enough frequencies the lead lengths can be inductive and modeled with the addition of a series inductor.
Memory effects are nonlinear.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
