Equivalent resistance in circuits
The top two resistors in the circuit are in parallel, resulting in an equivalent resistance of 0.6 ohms. This equivalent resistance can be placed at the nodes where the original resistors were connected. Placing it in either location will not affect the overall equivalent resistance of the entire circuit. The key takeaway is that the equivalent resistance must connect to the same nodes as the original resistors. Understanding these placements is crucial for accurate circuit analysis.
princejan7
http://postimg.org/image/p14d9faf9/
The top two resistors are in parallel, so their equivalent resistance is 0.6 ohms.
But if you were to draw the equivalent circuit, where do we place this equivalent resistance?
can it be placed either where the 1 ohm or 2 ohm resistors used to be?
would it affect my answer for the equivalent resistance of the whole circuit?
Don't forget about the "k"! :smile:
The two parallel resistors are attached to two distinct nodes. The equivalent resistance of those two resistors will be attached to the same two nodes.
No.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
