Error Calculation for a Diffraction Grating's Performance
The discussion revolves around calculating the error associated with the average value of the number of lines per meter (N) for a diffraction grating, based on multiple average angle measurements and their uncertainties. The context includes the propagation of errors from angle measurements into the calculation of N using the equation sin(θ) = pNλ.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss methods for calculating the uncertainty of the mean N value based on the uncertainties of the angle measurements. There are suggestions to use quadrature to combine uncertainties and questions about the applicability of weighted standard deviation.
The conversation is ongoing, with participants exploring different methods for error propagation and discussing the potential impact of measurement uncertainties. Some guidance has been offered regarding the use of quadrature for combining uncertainties, and one participant plans to consult with their lecturer for further clarification.
Participants are considering the implications of fixed-size errors in angular measurements and how they may affect the overall uncertainty in N. There is an acknowledgment of the small size of angle measurement errors, which may influence the choice of method for calculating the mean uncertainty.
zehkari
I need to calculate the error of an average value (N for diffraction grating).
My results were 4 different average angles. With which I calculated their uncertainty using std.
Using equation (1), I found the number of lines per meter (N) with a known wavelength (λ) and the correct diffraction order (p).
However, I now need an average of those 4 N values to find a mean N value.
What is my uncertainty on the mean N value, considering sin(θ) used in the equation is based off 4 results with their uncertainty?
I understand how to propagate error. I am just confused with how to take the 4 propagated errors based off the uncertainty of the angles to find an error on the mean N.
(1) sin(θ)=pNλ
My only idea would be adding all 4 propagation errors on N to give the total error for the average N?
Any help would be great, many thanks!
Suppose that your N values are ##N_1, N_2,...N_4## with uncertainties ##\Delta_1,\Delta_2,...,\Delta_4##. I'd think that the uncertainties should sum in quadrature (square root of sum of squares) and be divided by the number of samples. So:
$$\Delta_{avg} = \frac{1}{4}\sqrt{\sum_{i=0}^4{\Delta_i^2}}$$
what is your uncertainty in angle? You have a measurement equation, that determines your uncertainty.
Hey, thanks, do you know of the weighted standard diviation? Does that apply here?
I know of it. I'll state right away that I am not an expert in this area.
Having said that, I feel It might be applicable if the percent error in angular measurements is untowardly biasing the results (if Δθ is of fixed size then the fraction Δθ/θ becomes larger as θ gets smaller, even though you measure with the same accuracy).
Yeah, the error in angle measurements is quite small. I think I will stick with sum of uncertainty in quadrature like you suggested and then talk it over with my lecturer. Thank you for your help.
You're very welcome.
  • · Replies 25 ·
  • · Replies 17 ·
