Estimate Maximum Momentum You've Had: Physics Problem 10-1
  • Thread starter Thread starter Jimmy Snyder
The discussion revolves around a physics problem from a textbook that asks readers to estimate their maximum momentum and specify the reference frame. Participants debate the intended meaning of "maximum" and whether the authors expected creative interpretations of the reference frame, such as the center of the Earth or the Sun. Some argue that the question's phrasing encourages thinking beyond the conventional frame of reference, while others believe it primarily pertains to Earth's surface. The conversation also touches on another question from the book regarding universal expansion and the ambiguity in definitions of "size." Overall, the thread highlights the importance of context and interpretation in physics education.
Jimmy Snyder
I though you might like a light break to solve a problem probably more interesting than the author intended. This is from Physics, Classical and Modern, by Gettys, Keller, and Skove, 1989 (first?) edition. Question 10-1, page 220.
Estimate the maximum magnitude of momentum you have ever had. In what reference frame?
This is a text for a 2 or 3 semester physics survey course, so the typical reader may be unaware of some reference frames available for answering the question.
Meh. Unless you want to be unreasonably nitpicky (e.g., a blowhard) it's abundantly clear that the author means the only frame of reference which matters to 99.999% of people, which is relative to the Earth's surface.
If I'm allowed to interpret "maximum" as "supremum", then my answers to the two questions are "\infty" and "none":smile:. These are exact solutions, not estimates.
If I'm not allowed to do that then there is no exact solution.
So, how many points would you take off for those students with more imagination and sense of humor than the book's authors?
A. Einstein said:
The results of Mercury's perihelion movement fills me with great satisfaction. How helpful to us is astronomy's pedantic accuracy, which I used to secretly ricidule.
Did the words "In what reference frame?" appear in the textbook question, or were they added by jimmysnyder? If they appeared in the question, I think that was an intentional clue to get students to think of alternatives. I very much doubt the authors intended my response in post #3, but they may well have been inviting students to consider a centre-of-earth frame or a sun-centred frame (for example).
In the book. Here's another, from the first chapter on units of measurement. Question 1-4, page 10.
If you were told that everything in the universe had expanded to twice its former size while you slept last night, how would you check to see if it was true? What if all clocks suddenly ran at half speed? What if the mass of everything doubled? What if all those things happened simultaneously?
"Size" is not defined in the book, so it is unclear whether the authors mean length or volume, but volume makes more sense. Also unclear is whether students are allowed to apply what they know about the stability of the atom after having read about m, s, and kg.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
