Estimating Energy Generated by Niagara Falls
  • Thread starter Thread starter physics(L)10
    Energy
To estimate the energy generated by water falling over Niagara Falls in five days, the calculation begins with the height of 150 meters and a water flow rate of 104 m³/sec. The total time for the five days is calculated as 4,320,000 seconds. The potential energy is determined using the formula P = W/t, where W is the work done, calculated as mgh. The mass can be found by converting the flow rate into mass using the density of water, approximately 1000 kg/m³. This method provides a comprehensive approach to estimating the energy produced by the falls.
physics(L)10
Estimate E generated by water falling over Niagara falls in 5 day.
Height = 150m
Water flow =104m3/sec
t=5x24x60x60=4320000sec
P=W/t
mgh=mv2/2
Work=mgh=m(9.8)(150)
Time=432000seconds
P=m(1470)/4320000
I just don't know how to convert 104m3/sec into a mass
The density of water is ~1000kgm^{-3}.
You can use this to work out the mass flowing per second.
Alright niceee thanks for the help :)
No problemo :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
