Evaluate the definite integral and it exists
afcwestwarrior
a=0, b= pie/3 sin theta/ cos^2 theta
i let u= cos theta
du/dx= -sin theta
-du = sin theta
sin theta/u^2 theta
then i anti differentiated it
-cos theta/ (1/3)(cos)^3 theta
this is where i got stuck
i know how to do this problem but need help with the antidifferentiation
Did you mean
\int_{0}^{\pi / 3} \frac{ \sin \theta }{\cos^2 \theta}
? If so, that makes no sense: there is a very important part of this notation that has been omitted.
It looks like you were doing a substitution -- is there any particular reason why you didn't convert the expression entirely into a function of u?
yes that is what i meant, the reason is because sin and cos confuse me
I think I had this same problem not too long ago. sin(u)/cos(u) is a trig property that equals tan(u), and 1/cos(u) is the definition of sec(u). Therefore, the problem condenses to tan(u)sec(u)du, which you should recognize if you're on up to integration in your studies.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
