Evaluation of a (parabolic) line integral with respect to arc length
GelatinousFur
Evaluate the line integral \[ \int_c yz\,ds.\]
where C is a parabola with z=y^2 , x=1 for 0<=y<=2
A hint was given by the teacher to substitute p=t^2 , dp=(2t)dt and use integration by parts.
I also know from other line integrals with respect to arc length that:
ds=sqrt((dx/dt)^2 + (dy/dt)^2 + (dz/dt)^2)
I think that from the information given, the beginning and end points are (1,0,0) to (1,2,4).
My first guess is:
x(t) = t
y(t) = 2t
z(t) = t^2
This will be when t goes from 0 to 2.
So after I have parameterized the curve, I would substitute the functions of t back into the integral to get:
int((2t)^3*sqrt(1^2+2^2+(2t)^2),t,0,2)
=8*int(t^3*sqrt(4t^2+5),t,0,2)
=12032/3
This doesn't look right to me though. Any help would be appreciated!
Welcome to PF!
Hi GelatinousFur! Welcome to PF! :smile:
My first guess is:
x(t) = t
y(t) = 2t
z(t) = t^2
No, x is constant
x(t) = 1 :wink:
(and your y and z don't fit each other)
tiny-tim said:
Hi GelatinousFur! Welcome to PF! :smile:No, x is constant
x(t) = 1 :wink:
Ah, I see. Thanks for the help (and the welcome)!
So then...
X(t) is constant, so x(t)=1
y(t) =t
z(t) = t^2
The line integral would then become:
int(y^3,s) over the curve C, because z=y^2.
=int(t^3*sqrt(0^2+1^2+(2t)^2),t,0,2)
=int(t^3*2t,t,0,2)
=2*int(t^4,t,0,2)
=64/5
This answer feels a bit more correct but I still cannot see why the teacher gave us the hint to use integration by parts, as I didn't have to when I just performed that integral.
So then...
y(t) =t
z(t) = t^2
Hi
in you integrand you have
t^3\sqrt{1+4t^2}
I think you simplified away the one from the squareroot
GelatinousFur said:
=int(t^3*2t,t,0,2)
=2*int(t^4,t,0,2)
=64/5
lanedance said:
Hi
t^3\sqrt{1+4t^2}
Thanks, you are correct.
The correct integral is:
int(t^3*sqrt(1+4*t^2),t,0,2)
So here's where I use integration by parts, but when I integrate sqrt(1+4*t^2) I have to go to an integral table.
I punched int(t^3*sqrt(1+4*t^2),t,0,2) into MATLAB and it spits this answer out:
-1/64/pi^(1/2)*(-3128/15*pi^(1/2)*17^(1/2)-8/15*pi^(1/2))
Is this the wrong answer? Looks a bit weird to me.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
