Evaluation of Indefinite Integral
futurept
Evaluate the following indefinite integral: (2t6-3)/t3 dt
I know I need to substitute. Tried u= t3 and found du= 3t2dt. Tried to find where du would substitute in, but found nothing. Also tried u= 2t6-3. Found du=12t5dt and again cannot find where to sub in the du. Any suggestions on where I'm going wrong?
You don't need to substitute. \frac{2t^6 - 3}{t^3} = 2t^3 -3t^{-3}. Now all you need to do is find antiderivatives for those two functions, using the power rule.
Hey thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
